1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: pvlist does not find all servers in network
From: Florian Feldbauer via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk at aps.anl.gov
Date: Wed, 28 Jan 2026 16:24:22 +0100
Ok found the issue.
On the MPOD crate controller, nftable is used as firewall, not iptables....
The nftables config was:
  chain output {
    type filter hook output priority 0; policy drop;
followed by a list of a few ports/services on UDP and TCP that were allowed.
From the debug output below (e.g. " 2026-01-28T10:33:24.334 Sending 49 bytes 0.0.0.0:38188 -> 192.168.10.1:53857.")
I guess neither the source nor the destination port of the reply are fixed?
Which means, I basically have to change the rules to just accept all outbound UDP traffic (which I do not really see an issue with....it's in a local subnet anyway).
Cheers,
Florian
On 1/28/26 12:03, Florian Feldbauer via Tech-talk wrote:
Hey Andrew and Michael,
to answer the obvious questions:
  • Output from `uname -a`:
    root@iseg-iCS2-5230317:~# uname -a
    Linux iseg-iCS2-5230317 4.9.220-2.8.8+g93458a0ecf099 #1 SMP Fri May 16 07:15:45 UTC 2025 armv7l GNU/Linux
  • Broadcast address is 192.168.10.255 on all devices in this network.
  • On the MPOD is only one IOC running.
  • On the MPOD EPICS base 7.0.4.1 is running,
  • On my PC base 7.0.9 is installed.
In both cases the corresponding tag was recursively checked out from the git repository and build with the all submodules.
I know about `netstat -p` und normally use `-tulpn`, but:
root@iseg-iCS2-5230317:~# netstat -tulpn
netstat: invalid option -- 'p'
BusyBox v1.24.1 (2025-05-16 07:17:53 UTC) multi-call binary.
Usage: netstat [-ral] [-tuwx] [-en]
Using $EPICS_PVA_DEBUG=3 was a great tip! I thought receiving the UDP broadcast would be the issue but obviously sending a reply is:
2026-01-28T10:33:23.690 UDP Client Rx (37) 192.168.10.255:5076 <- 192.168.10.1:53857
2026-01-28T10:33:23.690 Message [0xUDP Server Rx (37) 192.168.10.255:5076 <- 192.168.10.1:538573, v0x2] received from 192.168.10.1:53857 on 192.168.10.255:5076 :
Message [0x3, v0x2] received from 192.168.10.1:53857 on Search
192.168.10.255:5076 : Search request0x00
0x0000000000  0000000081000000 000000000 81000000 00000000 000 000000000000  .... .... 00  ..... ......
0x10 00. .00ffff 00000000... 61d20000 . 00  ...      .. .... .... a..... .
0x10 0000ffff 00000000 61d20000 00        .... .... a... .
2026-01-28T10:33:23.754 Sending 49 bytes 0.0.0.0:38188 -> 192.168.10.1:53857.
2026-01-28T10:33:23.754 Socket sendto to 192.168.10.1:53857 error: Operation not permitted.
2026-01-28T10:33:23.956 UDP Client Rx (37) 192.168.10.255:5076 <- 192.168.10.1:53857
2026-01-28T10:33:23.956 Message [0xUDP Server Rx (37) 192.168.10.255:5076 <- 192.168.10.1:53857
Message [0x3, v0x2] received from 192.168.10.1:53857 on 3, v0x2] received from 192.168.10.1:53857 on 192.168.10.255:5076 : Search request
0x00 000000192.168.10.255:5076 : 00 81000000Search
0x00 00000000  00000000 000000810000  .... ...0000 . .00000... ...00.
00 0x10 0000ff0000ff 0000000000  ...0. ..00 .. ...61d2. 0000.. 00        ...... .... a... .
2026-01-28T10:33:24.024 Sending 49 bytes 0.0.0.0:38188 -> 192.168.10.1:53857.
2026-01-28T10:33:24.024 Socket sendto to 192.168.10.1:53857 error: Operation not permitted.
2026-01-28T10:33:24.212 UDP Client Rx (37) 192.168.10.255:5076 <- 192.168.10.1:53857
2026-01-28T10:33:24.212 Message [0xUDP Server Rx (37) 192.168.10.255:5076 <- 192.168.10.1:53857
Message [0x3, v0x3, v0x2] received from 192.168.10.1:53857 on 192.168.10.255:5076 : Search request2] received from 192.168.10.1:53857 on
0x192.168.10.255:5076 : 00 00000000 810000Search
00 000x00 000000000000000 81000000  000000000  ....00000000 000000 ...00  ... .... ....
0x10 0000ffff.. . 0000..0000 61d20000 . ....0 .00        .....
0x10 0000ff0.. .... a... .
2026-01-28T10:33:24.334 Socket sendto to 192.168.10.1:53857 error: Operation not permitted.
I don't know why there is an operation not permitted error.
The firewall should be open:
root@iseg-iCS2-5230317:~# iptables -L
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
Cheers,
Florian
On 1/28/26 02:40, Michael Davidsaver wrote:
Hello Florian,
First, the usual questions.  Which versions of epics-base and associated modules are involved?  Including pvDataCPP, pvAccessCPP, and pva2pva if built as separate modules.  Do you set any of the EPICS_PVA* environment variables?
On this MPOD crate.  Is there only the one IOC process?  fyi. you can add '-p' to 'netstat' and it will tell you which PID each socket is associated with.
As Andrew mentioned.  Setting $EPICS_PVA_DEBUG=3 will turn on a fire hose for logging.
From the output provided, PVXS is not present.  You might also try "pvxlist" and/or "softIocPVX" to see if the behavior differs.
On 1/27/26 4:02 AM, Florian Feldbauer via Tech-talk wrote:
Hey all,
I have a strange problem, that I haven't encountered before.
In our lab we have a small test setup for our pixel sensors.
As HV/LV power supply for these sensors we use a Wiener MPOD crate with an iseg Crate Controller.
The crate controller is running Linux (The Ångström Distribution v2017.12) and an EPICS IOC with PVA.
Now, when I run `pvlist` from another PC I see a list of all the IOCs running in this network except the one on the iseg Crate Controller.
When I explicitly run `pvlist iseg-iCS2-5230317` I get a list of all PVs from that IOC, so PVA communication works in general, but for some reason this IOC is not reacting on broadcasts.
I checked with netstat and for me this looks correct:
root@iseg-iCS2-5230317:~# netstat -tuln | grep 5076
udp        0      0 224.0.0.128:5076        0.0.0.0:*
udp        0      0 192.168.10.255:5076     0.0.0.0:*
udp        0      0 192.168.10.22:5076      0.0.0.0:*
udp        0      0 :::50767                :::*
There is no firewall running on the crate controller.
Any idea what could cause this issue?
Cheers,
Florian
Ruhr-Universität Bochum
AG der Experimentalphysik I
Dr. Florian Feldbauer
NB 2/131 / Fach 125
Universitätsstr. 150
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
NB 2/131 / Fach 125
D-44801 Bochum
Office: NB 2/134
Re: pvlist does not find all servers in network Michael Davidsaver via Tech-talk
pvlist does not find all servers in network Florian Feldbauer via Tech-talk
Re: pvlist does not find all servers in network Florian Feldbauer via Tech-talk
Prev: OmsAsyn Maxnet Homing Blomley, Edmund (IBPT) via Tech-talk
Next: RE: OmsAsyn Maxnet Homing Pearson, Matthew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: pvlist does not find all servers in network Florian Feldbauer via Tech-talk
Next: Re: pvlist does not find all servers in network Michael Davidsaver via Tech-talk
