1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: MAXnet Alarm State Under High Motor Command Load
From: "Peterson, Kevin M. via Tech-talk" <tech-talk at aps.anl.gov>
To: Jiajun Tian <jiajtian at uchicago.edu>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 11 Feb 2026 21:57:46 +0000
There is only one place in the MAXnet support where the problem bit of the MSTA is set, which is what causes the "Controller Error" to appear on the MEDM screen:
https://urldefense.us/v3/__https://gcc02.safelinks.protection.outlook.com/?url=https*3A*2F*2Fgithub.com*2Fepics-motor*2FmotorOmsAsyn*2Fblob*2Fc0ae4c740d699e64f264ce6f53f23a492abf19fa*2FomsAsynApp*2Fsrc*2FomsBaseController.cpp*23L759&data=05*7C02*7Ctech-talk*40aps.anl.gov*7Ccc2d03a3861b4ee14fef08de69b8973e*7C0cfca18525f749e38ae7704d5326e285*7C0*7C0*7C639064438676809432*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C&sdata=cLw1voHafqwu4rbu3uoCD2idv1pe78ejbw7qH3CSygQ*3D&reserved=0__;JSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJQ!!G_uCfscf7eWS!ZfqrByY1Leb0aWUy1ev9CMvZKuiNsJndx25RQWtp-6B3noy_-25BHDW0lq3hzIiCu8GV31kDIxifuuT-iOqCNQ4$
The error occurs when the controller reports that the axis is moving but the velocity queried by the driver using the RV command is zero for five consecutive moving poll periods.
Kevin
Re: MAXnet Alarm State Under High Motor Command Load Peterson, Kevin M. via Tech-talk
MAXnet Alarm State Under High Motor Command Load Jiajun Tian via Tech-talk
Re: MAXnet Alarm State Under High Motor Command Load Jiajun Tian via Tech-talk
Prev: Re: eiger2 vacuum sequencing power status Guruswamy, Tejas via Tech-talk
Next: Re: eiger2 vacuum sequencing power status Maren Purves via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: MAXnet Alarm State Under High Motor Command Load Jiajun Tian via Tech-talk
Next: Re: MAXnet Alarm State Under High Motor Command Load Peterson, Kevin M. via Tech-talk
