1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: IR cameras
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>, "Wang, SuYin Grass" <grass at anl.gov>
Date: Mon, 23 Feb 2026 16:23:47 +0000
Hi Grass,
I looked at the specifications for the FLIR AX8 here:
It says that the camera can stream images in Motion JPEG, MPEG, and H.264 formats.  That suggests that you may be able to use ADURL, which works for reading from URLs in formats that include JPEG.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Wang, SuYin Grass via Tech-talk <tech-talk at aps.anl.gov>
Sent: Monday, February 23, 2026 8:48 AM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: IR cameras
We currently have an FLIR AX8 and an Optris PI-1M. Does anyone have the  EPICS support for it already?
The FLIR AX8 doesn’t support Aravis, so ADAravis won’t work.
Are there recommended IR cameras that integrate well with EPICS (ideally via an existing areaDetector driver)?
Thank you!
Grass
Re: IR cameras Wang, SuYin Grass via Tech-talk
Prev: Collaboration on use of EPICS for engine rig control (Single-Cylinder Engine Test Cell at Chalmers University Of Technology in Gothenburg) Djordje Purkovic via Tech-talk
Next: Re: Record TIME field taken from another record's VAL Torsten Bögershausen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: IR cameras Wang, SuYin Grass via Tech-talk
Next: Re: IR cameras Wang, SuYin Grass via Tech-talk
ANJ, 24 Mar 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
