1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: ADAndor IOC Restart Issue: Camera Handle Already Claimed After Ctrl+X Termination
From: "Hu, Yong via Tech-talk" <tech-talk at aps.anl.gov>
To: Mark Rivers <rivers at cars.uchicago.edu>, Kuktae Kim <ktkim at slac.stanford.edu>
Cc: Tech-Talk EPICS <tech-talk at aps.anl.gov>
Date: Thu, 5 Mar 2026 16:15:51 +0000
In procServ, Ctrl+X is the “kill child” command by default (--killcmd, default ^X). When procServ receives it, it kills the child process using --killsig, whose default is signal 9 (SIGKILL). SIGKILL cannot be handled by the IOC, so no cleanup runs.
If you really want to use Ctrl + X,  here is ChatGPT's suggestion: one way is to modify your procServ command, passing --killsig=2
1) Don’t use Ctrl+X for restart (quickest fix)
Use exit in the iocsh (or whatever clean shutdown mechanism you already have). That’s why Ctrl+C / exit works for you: it lets the IOC unwind and release the camera cleanly.
2) Reconfigure procServ so its “kill” is graceful
If you want a single-keystroke restart from procServ, change procServ’s kill signal away from SIGKILL:
  • Prefer SIGTERM (15) or SIGINT (2) instead of 9
  • Optionally change the kill command character so it’s harder to hit accidentally
From the procServ man page: --killsig defaults to 9 (SIGKILL), and -k/--killcmd defaults to ^X.
Example pattern (adjust to your startup scripts):
  • procServ ... --killsig=15 ...
  • or procServ ... --killsig=2 ...
  • or disable the kill keystroke entirely: --killcmd=""
Also consider increasing --holdoff if your procServ auto-restarts very quickly; procServ already enforces a minimum restart interval (default 15 s), but some devices/driver stacks benefit from more.
Cheers,
Yong
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
Date: Thursday, March 5, 2026 at 9:12 AM
It seems like Ctrl + X kills the IOC in a way that prevents the exit handlers from running. Others may be able to provide guidance on how to trap that. But just advising users to exit the IOC with “exit” or Ctrl C is a workaround.
Sent from my iPhone
On Mar 5, 2026, at 8:01 AM, Kim, Kuktae via Tech-talk <tech-talk at aps.anl.gov> wrote:
Hello,
I am currently developing an areaDetector IOC using the ADAndor module for the Andor iXon Ultra 888 CCD camera. We are using procServ for process management and telnet access.
When restarting the IOC, I do not encounter any issues if I type exit in the iocShell or press Ctrl + C. However, when I press Ctrl + X, I receive the following error message upon restarting the IOC:
andorCCDConfig("CAM", "/usr/local/etc/andor/", 9059, 0, 0, 0, 0, 0)
andorCCD:AndorCCD: initializing camera with handle 100, installDir: /usr/local/etc/andor/
andorCCD:AndorCCD: camera with handle 100 not available (already claimed?)
2026/03/04 18:46:02.652 andorCCD::AndorCCD camera not detected!
We are currently using:
  • EPICS Base: R7.0.3.1
  • ADCore: R3.10
  • ADAndor: R2-8
Could you please provide any advice on what might be causing this issue? It would be greatly appreciated. Thank you.
Best regards,
Kuktae
Re: ADAndor IOC Restart Issue: Camera Handle Already Claimed After Ctrl+X Termination Henrique F. Simoes via Tech-talk
ADAndor IOC Restart Issue: Camera Handle Already Claimed After Ctrl+X Termination Kim, Kuktae via Tech-talk
Re: ADAndor IOC Restart Issue: Camera Handle Already Claimed After Ctrl+X Termination Mark Rivers via Tech-talk
Prev: Re: ADAndor IOC Restart Issue: Camera Handle Already Claimed After Ctrl+X Termination Mark Rivers via Tech-talk
Next: Re: Help in debugging ACF connection issue Hu, Yong via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Next: Re: ADAndor IOC Restart Issue: Camera Handle Already Claimed After Ctrl+X Termination Henrique F. Simoes via Tech-talk
