1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: RE: Strange problem when compiling sscanRecord.c on Windows
From: Freddie Akeroyd - STFC UKRI via Tech-talk <tech-talk at aps.anl.gov>
To: Mark Rivers <rivers at cars.uchicago.edu>, EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Mon, 4 May 2026 00:12:11 +0000
Hi Mark,
If you set whole program optimisation to NO (   https://github.com/epics-base/epics-base/blob/ac0fc2effff43c9db116ae68c91f3a9767c991ec/configure/os/CONFIG.win32-x86.win32-x86#L13 )
   does it speed things up for windows-x64? For windows-x64-static this should already be disabled via  https://github.com/epics-base/epics-base/blob/ac0fc2effff43c9db116ae68c91f3a9767c991ec/configure/os/CONFIG_SITE.Common.windows-x64-static#L8
Freddie
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Mark Rivers via Tech-talk
Sent: 01 May 2026 19:16
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Subject: Strange problem when compiling sscanRecord.c on Windows
Folks,
I have noticed that compiling the EPICS scan record (https://github.com/epics-modules/sscan/blob/master/sscanApp/src/sscanRecord.c) is extraordinarily slow on Windows with Visual Studio.
This is my environment:
Base 7.0.10
Visual Studio compiler version: Microsoft (R) C/C++ Optimizing Compiler Version 19.44.35215 for x64
sscanRecord version: master branch in the link above.
I tested by deleting all of the xxxRecord.obj files in the O.windows-64 or O.windows-x64-static directories and then timing how long it took "make" to complete.  This is the time to both compile the xxxRecord.c files and the time to link the relevant library.  "make" was run without the -j option, so the build was sequential, not parallel.
The following table compares the time to compile and link the relevant library for a number of EPICS records on both static builds (windows-x64-static) and dynamic builds (windows-x64).
Files
Total lines of C code
Time (s) for windows-x64
Time (s) for windows-x64-static
All 34 record files in base/modules/database/src/std/rec
 13,369
54
59
All 5 record files in calc/calcApp/src
5,460
30
23
sscanRecord.c
5,596
242
251
This is what I see with Windows TaskManager when compiling sscanRecord.c and linking the library:
  • On  windows-x64-static the compiler (cl.exe) is using 100% of a core for most of the 251 seconds.
  • On windows-x64 the linker (link.exe) is using 100% of a core for most of the 242 seconds.
This seems very strange to me.  It is taking 8-10 times longer to compile and link sscanRecord.c than it does to compile and link essentially the same number of lines of record code for the 5 records in calcApp.
Any ideas?
Re: Strange problem when compiling sscanRecord.c on Windows Peterson, Kevin M. via Tech-talk
Strange problem when compiling sscanRecord.c on Windows Mark Rivers via Tech-talk
Prev: Televac MM200 questions James P. Withrow via Tech-talk
Next: RE: Understanding alarms, alarm server and notification usage in other facilities Blomley, Edmund (IBPT) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Strange problem when compiling sscanRecord.c on Windows Mark Rivers via Tech-talk
Next: Re: Strange problem when compiling sscanRecord.c on Windows Peterson, Kevin M. via Tech-talk
ANJ, 07 May 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
