1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: Televac MM200 questions
From: "Smith, Martin via Tech-talk" <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>, "James P. Withrow" <jwithrow at cornell.edu>
Date: Mon, 4 May 2026 10:46:27 +0000
Hi Jim,
While I don't recall any specific issues with the 2.18 version of firmware, I do know that we did have some issues with version 2.34
and found that version 2.13 was a stable one. It has been a long time since I have looked at these devices as I think we are mostly
using MX200s now. You could copy the EEPROM from a 2.18 device and reprogram the one you are having issues with.
Marty Smith
ANL / APS Controls Group
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of James P. Withrow via Tech-talk <tech-talk at aps.anl.gov>
Sent: Sunday, May 3, 2026 1:48 PM
Subject: Televac MM200 questions
Hello all -
I'm in the process of moving instrumentation on our beamline to EPICS-based solutions instead of bespoke hardware/software combinations. I've recently moved the vacuum readouts (Televac MM200) and ion pumps (Digitel MPC) to IOCs using the synApps 'vac' module. This solution works perfectly for both the gauges and the pumps - with the exception of one set of Televac gauges. The set of gauges which works is using firmware rev. 2.13, while the one having issues is on 2.18. The latter set will run normally for 20-30 seconds, and then appear to hang. Once the vac module times out, it attempts to send its next query which confuses the gauge (returns 'R?') but then starts working again.
Has anyone else encountered this issue and are there any possible tuning options for the serial communications?
Thank you in advance,
-Jim
Jim Withrow, Research Support Specialist - jwithrow at cornell.edu
NE-CAT, Cornell University - https://necat.chem.cornell.edu
Advanced Photon Source, Sector 24
9700 S. Cass Avenue, Building 436 E001
Lemont, IL 60439
Re: Televac MM200 questions James P. Withrow via Tech-talk
Prev: RE: Understanding alarms, alarm server and notification usage in other facilities Blomley, Edmund (IBPT) via Tech-talk
Next: Re: Televac MM200 questions James P. Withrow via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Televac MM200 questions James P. Withrow via Tech-talk
ANJ, 04 May 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
