1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Subject: Re: PVA OUT Links in EPICS:
From: Michael Davidsaver via Tech-talk <tech-talk at aps.anl.gov>
To: Varuna Crishan Meddage <vmeddage at fnal.gov>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Mon, 8 Jun 2026 17:36:19 -0700
On 6/8/26 4:13 PM, Varuna Crishan Meddage via Tech-talk wrote:
I tried different tricks for example setting field(VAL, "0") and field(PINI, "YES"), but none of them was successful.
I should also note that setting PINI to YES will leave this record with a INVALID LINK alarm as the PVA link is unlikely to be connected by the time of the initial process scan.
Depending on your desired reconnect behavior, you may wish to investigate the "retry" link option.
retry. For an output link, and true (not default), then the most recent incomplete PUT will be re-tried when the target PV (re)connects.
https://epics-base.github.io/pvxs/pvalink.html
Re: PVA OUT Links in EPICS: Varuna Crishan Meddage via Tech-talk
Prev: Re: PVA OUT Links in EPICS: Michael Davidsaver via Tech-talk
Next: Phoebus 4.7 — `lsi`/`lso` long strings, `.$` PV names, and macro “not fully resolved” warnings Gofron, Kaz via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Next: Re: PVA OUT Links in EPICS: Varuna Crishan Meddage via Tech-talk
ANJ, 09 Jun 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
