1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Subject: Re: Phoebus 4.7 — `lsi`/`lso` long strings, `.$` PV names, and macro “not fully resolved” warnings
From: "Gofron, Kaz via Tech-talk" <tech-talk at aps.anl.gov>
To: "Kasemir, Kay" <kasemirk at ornl.gov>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 12 Jun 2026 14:07:12 +0000
Hi Kay,
Thank you for investigating this and for the clarification.
It's good to know that using NameOfLongString.$ (or NameOfLongString.VAL$) is the correct approach for reading EPICS long strings, and that the Phoebus "not fully resolved" warning is simply a false positive caused by the trailing $ being mistaken for an unresolved macro.
That explains the behavior we were seeing. We'll continue using the .$ syntax and ignore the warning for now. It's also great to hear that this has already been addressed and will disappear in an upcoming Phoebus release.
I appreciate your help.
Best regards,
Kaz
Sent: Friday, June 12, 2026 9:53 AM
To: Gofron, Kaz <gofronkj at ornl.gov>; tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Hi:
To read long strings, you do need to use NameOfLongString.VAL$ or NameOfLongString.$
The display warning is misleading, it mistakes any remaining ‘$’ for an unresolved macro.
You can simply ignore the warning, it will go away in an upcoming phoebus update, https://github.com/ControlSystemStudio/phoebus/pull/3831
-Kay
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Gofron, Kaz via Tech-talk <tech-talk at aps.anl.gov>
Date: Tuesday, June 9, 2026 at 1:31 AM
`caget -S TAS:Plot:SelectedFile.$`
On **every screen reload**, however, the Phoebus terminal logs warnings such as:
Widget 'SelectedFile' (textentry) 'pv_name' is not fully resolved: 'TAS:Plot:SelectedFile.$'
Phoebus 4.7 — `lsi`/`lso` long strings, `.$` PV names, and macro “not fully resolved” warnings Gofron, Kaz via Tech-talk
Re: Phoebus 4.7 — `lsi`/`lso` long strings, `.$` PV names, and macro “not fully resolved” warnings Kasemir, Kay via Tech-talk
Prev: Re: Phoebus 4.7 — `lsi`/`lso` long strings, `.$` PV names, and macro “not fully resolved” warnings Kasemir, Kay via Tech-talk
Next: Auto-Scaling in Phoebus Display Builder Vishnu Patel via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Next: Wrapper of pyepics and p4p Wang, Lin via Tech-talk
ANJ, 16 Jun 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
