Looking for advice from anyone who has experience running an IOC under RTEMS on a Beaglebone Black. It
looks like I can load the IOC image and the it starts executing , but
it seems like it stops stops when it can't find the ethernet interface. Here is the console output of the boot up: U-Boot 2016.11-rc3-00002-g73df7f7 (Nov 04 2016 - 15:20:36 -0500), Build: jenkin9
CPU : AM335X-GP rev 2.1 I2C: ready DRAM: 512 MiB Reset Source: Global external warm reset has occurred. Reset Source: Power-on reset has occurred. MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1 Using default environment Board: BeagleBone Black <ethaddr> not set. Validating first E-fuse MAC Net: eth0: MII MODE cpsw Press SPACE to abort autoboot in 2 seconds board_name=[A335BNLT] ... board_rev=[00C0] ... switch to partitions #0, OK mmc0 is current device SD/MMC found on device 0 ** Bad device 0:2 0x82000000 ** ** Bad device 0:2 0x82000000 ** switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... reading /am335x-boneblack.dtb 99116 bytes read in 15 ms (6.3 MiB/s) gpio: pin 56 (gpio 56) value is 0 gpio: pin 55 (gpio 55) value is 0 gpio: pin 54 (gpio 54) value is 0 gpio: pin 53 (gpio 53) value is 1 switch to partitions #0, OK mmc0 is current device gpio: pin 54 (gpio 54) value is 1 Checking for: /uEnv.txt ... reading uEnv.txt 173 bytes read in 5 ms (33.2 KiB/s) gpio: pin 55 (gpio 55) value is 1 Loaded environment from /uEnv.txt Importing environment from mmc ... Checking if uenvcmd is set ... gpio: pin 56 (gpio 56) value is 1 Running uenvcmd ... link up on port 0, speed 100, full duplex BOOTP broadcast 1 DHCP client bound to address 192.168.0.186 (6 ms) Using cpsw device TFTP from server 192.168.0.143; our IP address is 192.168.0.186 Filename 'rtems-app.img'. Load address: 0x80800000 Loading: ################################################################# ################################################################# ############################################################### 2.5 MiB/s done Bytes transferred = 2819094 (2b0416 hex) link up on port 0, speed 100, full duplex BOOTP broadcast 1 DHCP client bound to address 192.168.0.186 (7 ms) Using cpsw device TFTP from server 192.168.0.143; our IP address is 192.168.0.186 Filename 'am335x-boneblack.dtb'. Load address: 0x88000000 Loading: ####### 2 MiB/s done Bytes transferred = 99116 (1832c hex) ## Booting kernel from Legacy Image at 80800000 ... Image Name: sampleIOC Created: 2026-06-15 16:44:43 UTC Image Type: ARM Linux Kernel Image (gzip compressed) Data Size: 2819030 Bytes = 2.7 MiB Load Address: 80000000 Entry Point: 80000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Uncompressing Kernel Image ... OK Loading Device Tree to 8ffe4000, end 8ffff32b ... OK Starting kernel ... RTEMS Beagleboard: am335x-based ARM Debug: 0x4b141000 WARNING: OS Clock time was read before being set. Using 1990-01-02 00:00:00.000000 UTC initConsole --- Info --- stdin: fileno: 0, ttyname: /dev/console stdout: fileno: 1, ttyname: /dev/console stderr: fileno: 2, ttyname: /dev/console time set to : 04/14/14 07:30:06.000002041 UTC Startup. epicsThreadSetPriority called by non epics thread ***** RTEMS Version: rtems-6.0.0 (ARM/ARMv4/beagleboneblack) ***** ***** Initializing network (libbsd, dhcpcd) ***** nexus0: <RTEMS Nexus device> ofwbus0: <Open Firmware Device Tree> on nexus0 ***** ifconfig lo0 ***** info: lo0: link state changed to UP ***** add dhcpcd hook ***** ***** Start default network dhcpcd ***** --Info (hpj)-- bsd task prio IRQS: 96 ----- --Info (hpj)-- bsd task prio TIME: 98 ----- ---- Waiting for DHCP ... info: version 6.2.1 starting err: no valid interfaces found warning: no interfaces have a carrier
| ANJ, 16 Jun 2026 |
Home
News
About
Talk
Base
Modules
Extensions
