HI Marcio,
I'm not quite sure what you're asking for here, or who you're addressing. We do now have a CONTRIBUTING.md file in the top of the source tree. It asks that all new features come with automated unit tests, but it doesn't currently mention adding documentation
at all. Maybe an addition to that document would be the appropriate place for your suggestion?
- Andrew
Complexity comes for free, Simplicity you have to work for.
On 7/28/26, 12:28 PM, "Donadio, Marcio Paduan" <marcio at slac.stanford.edu> wrote:
This Message Is From an External Sender
This message came from outside your organization.
I’ve been incentivizing my team to add documentation or test code for the pull requests when it makes sense. Maybe we could request this from EPICS pull request authors?
Cheers,
Marcio Donadio
Embedded Systems Engineer | TID-ID-CSE
SLAC National Accelerator Laboratory
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Johnson, Andrew N. via Tech-talk <tech-talk at aps.anl.gov>
Date: Wednesday, June 17, 2026 at 18:42
To: David Bracey <dbracey at fnal.gov>; tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: Re: IOCs - What are the built-in device types?
Hi Dave,
The published output from my pull request documenting the built-in device support can be found
here, beware any AI hallucinations or dragons that may be present. Review comments and suggestions can go
here if you have any.
Hope it helps!
- Andrew
On 6/17/26, 11:14 AM, "Tech-talk" <tech-talk-bounces at aps.anl.gov> wrote:
Hi Dave,
Great question, unfortunate answer: The current documentation doesn’t really cover those other DTYPs. Many of the record types have some documentation on their own soft and raw soft channel support, and there were entries in the Release Notes for some of the
newer device supports that were integrated. The list of device support layers provided by Base can be found in the dbd/devSoft.dbd file of any EPICS 7 release after building, and it’s worth doing a Google search for any specific layer you’re interested in,
but you might end up having to read the source to get some specific details at the moment (or ask here).
I may follow up with something written by Claude Code, which I have asked to fill in those gaps.
- Andrew
On 6/17/26, 9:44 AM, "Tech-talk" <tech-talk-bounces at aps.anl.gov> wrote:
There are apparently built-in device types that provide various useful data sources:
# get the current time-of-day
field(DTYP, "Soft Timestamp")
field(INP, "@%m/%d/%Y %H:%M:%S%z")
# get the specified environment variable
field(DTYP, "getenv")
field(INP, "@ENGINEER")
Where can I find documentation of these built-in DTYP's?
- Re: IOCs - What are the built-in device types? Donadio, Marcio Paduan via Tech-talk
- IOCs - What are the built-in device types? David Bracey via Tech-talk
- Re: IOCs - What are the built-in device types? Johnson, Andrew N. via Tech-talk
CSS Phoebus integration Luis Alberto De Sousa Moreira via Tech-talk
2025
<2026>
2025
<2026>
ANJ, 29 Jul 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
