1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Subject: Error building quadEM
From: Jesse Hopkins via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech-Talk <tech-talk at aps.anl.gov>
Date: Fri, 7 Aug 2026 17:49:13 +0000
Hi folks,
I’m attempting to build quadem (and all the other synapps modules) on a fresh install of Ubuntu 24.04.4 LTS. I figured I might as well grab the newest version of quadem, so I’m working off of the latest version on the git. When the synapps build (just doing make in the support folder) gets to quadem I get the following error:
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -MM -MF drvFX4.d  ../drvFX4.cpp
In file included from ../msgpack-c/include/msgpack/v1/pack_decl.hpp:15,
                 from ../msgpack-c/include/msgpack/pack_decl.hpp:13,
                 from ../msgpack-c/include/msgpack/pack.hpp:13,
                 from ../msgpack-c/include/msgpack/v1/object_decl.hpp:14,
                 from ../msgpack-c/include/msgpack/object_decl.hpp:14,
                 from ../msgpack-c/include/msgpack/object.hpp:13,
                 from ../msgpack-c/include/msgpack.hpp:10,
                 from ../drvFX4.h:24,
                 from ../drvFX4.cpp:35:
../msgpack-c/include/msgpack/sysdep.hpp:168:5: error: #error msgpack-c supports only big endian and little endian
  168 | #   error msgpack-c supports only big endian and little endian
../msgpack-c/include/msgpack/v1/pack_decl.hpp:82:2: error: #error msgpack-c supports only big endian and little endian
   82 | #error msgpack-c supports only big endian and little endian
In file included from ../msgpack-c/include/msgpack/pack_decl.hpp:14:
../msgpack-c/include/msgpack/v2/pack_decl.hpp:47:2: error: #error msgpack-c supports only big endian and little endian
   47 | #error msgpack-c supports only big endian and little endian
In file included from ../msgpack-c/include/msgpack/pack_decl.hpp:15:
../msgpack-c/include/msgpack/v3/pack_decl.hpp:46:2: error: #error msgpack-c supports only big endian and little endian
   46 | #error msgpack-c supports only big endian and little endian
In file included from ../msgpack-c/include/msgpack/pack.hpp:15:
../msgpack-c/include/msgpack/v1/pack.hpp:717:2: error: #error msgpack-c supports only big endian and little endian
  717 | #error msgpack-c supports only big endian and little endian
Installing dbd file ../../../dbd/drvFX4.dbd
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -c ../drvFX4.cpp
../msgpack-c/include/msgpack/sysdep.hpp:102:10: fatal error: boost/predef/other/endian.h: No such file or directory
  102 | #include <boost/predef/other/endian.h>
compilation terminated.
make[4]: *** [/opt/epics/base/configure/RULES_BUILD:268: drvFX4.o] Error 1
make[4]: Leaving directory '/opt/epics/synApps_6_3/support/quadEM-master/quadEMApp/FX4Src/O.linux-x86_64'
make[3]: *** [/opt/epics/base/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[3]: Leaving directory '/opt/epics/synApps_6_3/support/quadEM-master/quadEMApp/FX4Src'
make[2]: *** [/opt/epics/base/configure/RULES_DIRS:85: FX4Src.install] Error 2
make[2]: Leaving directory '/opt/epics/synApps_6_3/support/quadEM-master/quadEMApp'
make[1]: *** [/opt/epics/base/configure/RULES_DIRS:85: quadEMApp.install] Error 2
make[1]: Leaving directory '/opt/epics/synApps_6_3/support/quadEM-master'
make: *** [/opt/epics/base/configure/RULES_DIRS:85: /opt/epics/synApps_6_3/support/quadEM-master.install] Error 2
Any thoughts on what’s going on here? Should I just revert to a slightly older/less in development version?
At the bottom of this message I’ve included all the make output from quadem.
All the best.
- Jesse
Jesse Hopkins, PhD (he/him)
Director, BioCAT
Sector 18, Advanced Photon Source
Research Associate Professor, Illinois Tech
make -C /opt/epics/synApps_6_3/support/quadEM-master install
make[1]: Entering directory '/opt/epics/synApps_6_3/support/quadEM-master'
make -C ./configure install
make[2]: Entering directory '/opt/epics/synApps_6_3/support/quadEM-master/configure'
perl -CSD /opt/epics/base/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../..
mkdir -p O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[3]: Entering directory '/opt/epics/synApps_6_3/support/quadEM-master/configure/O.linux-x86_64'
perl -CSD /opt/epics/base/bin/linux-x86_64/convertRelease.pl checkRelease
make[3]: Leaving directory '/opt/epics/synApps_6_3/support/quadEM-master/configure/O.linux-x86_64'
make[2]: Leaving directory '/opt/epics/synApps_6_3/support/quadEM-master/configure'
make -C ./quadEMApp install
make[2]: Entering directory '/opt/epics/synApps_6_3/support/quadEM-master/quadEMApp'
make -C ./quadEMSrc install
make[3]: Entering directory '/opt/epics/synApps_6_3/support/quadEM-master/quadEMApp/quadEMSrc'
perl -CSD /opt/epics/base/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
mkdir -p O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
make[4]: Entering directory '/opt/epics/synApps_6_3/support/quadEM-master/quadEMApp/quadEMSrc/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include            -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include        -MM -MF drvSoftQuadEM.d  ../drvSoftQuadEM.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include            -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include        -MM -MF drvQuadEM.d  ../drvQuadEM.cpp
Installing generic include file ../../../include/drvQuadEM.h
mkdir ../../../include
Installing dbd file ../../../dbd/drvSoftQuadEM.dbd
mkdir ../../../dbd
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include        -c ../drvQuadEM.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include        -c ../drvSoftQuadEM.cpp
/usr/bin/ar -rc    libquadEM.a     drvQuadEM.o drvSoftQuadEM.o
/usr/bin/ranlib libquadEM.a
/usr/bin/g++ -o libquadEM.so  -shared -fPIC -Wl,-hlibquadEM.so -L/opt/epics/synApps_6_3/support/quadEM-master/lib/linux-x86_64 -L/opt/epics/base/lib/linux-x86_64 -L/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/lib/linux-x86_64 -L/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/lib/linux-x86_64 -L/opt/epics/synApps_6_3/support/asyn-R4-46/lib/linux-x86_64 -Wl,-rpath,/opt/epics/synApps_6_3/support/quadEM-master/lib/linux-x86_64 -Wl,-rpath,/opt/epics/base/lib/linux-x86_64 -Wl,-rpath,/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/lib/linux-x86_64 -Wl,-rpath,/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/lib/linux-x86_64 -Wl,-rpath,/opt/epics/synApps_6_3/support/asyn-R4-46/lib/linux-x86_64          -rdynamic -m64          drvQuadEM.o drvSoftQuadEM.o   -lADBase -lasyn -lntndArrayConverter -lnt -lpvDatabase -lpvAccess -lpvData -lnetCDF -lnanohttp_stream -lMagick++ -lcoders -lMagick -ljbig -ljp2 -lbzlib -lpng -lwebp -llcms -lttf -lwmf -lfilters -ltiff -lxml2 -lNeXus -lhdf5_hl -lhdf5 -lbitshuffle -llz4hdf5 -lblosc -lszip -lzlib -ljpeg -ldbRecStd -ldbCore -lca -lCom  -lX11 -lXext -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64/libquadEM.so
Installing library ../../../lib/linux-x86_64/libquadEM.a
make[4]: Leaving directory '/opt/epics/synApps_6_3/support/quadEM-master/quadEMApp/quadEMSrc/O.linux-x86_64'
make[3]: Leaving directory '/opt/epics/synApps_6_3/support/quadEM-master/quadEMApp/quadEMSrc'
make -C ./caenSrc install
make[3]: Entering directory '/opt/epics/synApps_6_3/support/quadEM-master/quadEMApp/caenSrc'
mkdir -p O.Common
make[4]: Entering directory '/opt/epics/synApps_6_3/support/quadEM-master/quadEMApp/caenSrc/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include        -MM -MF drvTetrAMM.d  ../drvTetrAMM.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include        -MM -MF drvAHxxx.d  ../drvAHxxx.cpp
Installing dbd file ../../../dbd/drvAHxxx.dbd
Installing dbd file ../../../dbd/drvTetrAMM.dbd
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include        -c ../drvAHxxx.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include        -c ../drvTetrAMM.cpp
/usr/bin/ar -rc    libcaenQuadEM.a     drvAHxxx.o drvTetrAMM.o
/usr/bin/ranlib libcaenQuadEM.a
/usr/bin/g++ -o libcaenQuadEM.so  -shared -fPIC -Wl,-hlibcaenQuadEM.so -L/opt/epics/synApps_6_3/support/quadEM-master/lib/linux-x86_64 -L/opt/epics/base/lib/linux-x86_64 -L/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/lib/linux-x86_64 -L/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/lib/linux-x86_64 -L/opt/epics/synApps_6_3/support/asyn-R4-46/lib/linux-x86_64 -Wl,-rpath,/opt/epics/synApps_6_3/support/quadEM-master/lib/linux-x86_64 -Wl,-rpath,/opt/epics/base/lib/linux-x86_64 -Wl,-rpath,/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/lib/linux-x86_64 -Wl,-rpath,/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/lib/linux-x86_64 -Wl,-rpath,/opt/epics/synApps_6_3/support/asyn-R4-46/lib/linux-x86_64          -rdynamic -m64          drvAHxxx.o drvTetrAMM.o   -lADBase -lasyn -lntndArrayConverter -lnt -lpvDatabase -lpvAccess -lpvData -lnetCDF -lnanohttp_stream -lMagick++ -lcoders -lMagick -ljbig -ljp2 -lbzlib -lpng -lwebp -llcms -lttf -lwmf -lfilters -ltiff -lxml2 -lNeXus -lhdf5_hl -lhdf5 -lbitshuffle -llz4hdf5 -lblosc -lszip -lzlib -ljpeg -ldbRecStd -ldbCore -lca -lCom -lquadEM  -lX11 -lXext -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64/libcaenQuadEM.so
Installing library ../../../lib/linux-x86_64/libcaenQuadEM.a
make[4]: Leaving directory '/opt/epics/synApps_6_3/support/quadEM-master/quadEMApp/caenSrc/O.linux-x86_64'
make[3]: Leaving directory '/opt/epics/synApps_6_3/support/quadEM-master/quadEMApp/caenSrc'
make -C ./nslsSrc install
make[3]: Entering directory '/opt/epics/synApps_6_3/support/quadEM-master/quadEMApp/nslsSrc'
mkdir -p O.Common
make[4]: Entering directory '/opt/epics/synApps_6_3/support/quadEM-master/quadEMApp/nslsSrc/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall  -DSIMULATION_MODE -DPOLLING_MODE    -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include        -MM -MF drvNSLS2_EM.d  ../drvNSLS2_EM.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include        -MM -MF drvNSLS_EM.d  ../drvNSLS_EM.cpp
Installing dbd file ../../../dbd/drvNSLS_EM.dbd
Installing dbd file ../../../dbd/drvNSLS2_EM.dbd
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include        -c ../drvNSLS_EM.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall  -DSIMULATION_MODE -DPOLLING_MODE    -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include        -c ../drvNSLS2_EM.cpp
../drvNSLS2_EM.cpp: In member function ‘asynStatus drvNSLS2_EM::getFirmwareVersion()’:
../drvNSLS2_EM.cpp:440:13: warning: ‘char* __builtin_strncpy(char*, const char*, long unsigned int)’ output truncated before terminating nul copying as many bytes from a string as its length [-Wstringop-truncation]
  440 |      strncpy(firmwareVersion_,tmpstr, strlen(tmpstr));
../drvNSLS2_EM.cpp:440:13: note: length computed here
/usr/bin/ar -rc    libnslsQuadEM.a     drvNSLS_EM.o drvNSLS2_EM.o
/usr/bin/ranlib libnslsQuadEM.a
/usr/bin/g++ -o libnslsQuadEM.so  -shared -fPIC -Wl,-hlibnslsQuadEM.so -L/opt/epics/synApps_6_3/support/quadEM-master/lib/linux-x86_64 -L/opt/epics/base/lib/linux-x86_64 -L/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/lib/linux-x86_64 -L/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/lib/linux-x86_64 -L/opt/epics/synApps_6_3/support/asyn-R4-46/lib/linux-x86_64 -Wl,-rpath,/opt/epics/synApps_6_3/support/quadEM-master/lib/linux-x86_64 -Wl,-rpath,/opt/epics/base/lib/linux-x86_64 -Wl,-rpath,/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/lib/linux-x86_64 -Wl,-rpath,/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/lib/linux-x86_64 -Wl,-rpath,/opt/epics/synApps_6_3/support/asyn-R4-46/lib/linux-x86_64          -rdynamic -m64          drvNSLS_EM.o drvNSLS2_EM.o   -lADBase -lasyn -lntndArrayConverter -lnt -lpvDatabase -lpvAccess -lpvData -lnetCDF -lnanohttp_stream -lMagick++ -lcoders -lMagick -ljbig -ljp2 -lbzlib -lpng -lwebp -llcms -lttf -lwmf -lfilters -ltiff -lxml2 -lNeXus -lhdf5_hl -lhdf5 -lbitshuffle -llz4hdf5 -lblosc -lszip -lzlib -ljpeg -ldbRecStd -ldbCore -lca -lCom -lquadEM  -lX11 -lXext -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64/libnslsQuadEM.so
Installing library ../../../lib/linux-x86_64/libnslsQuadEM.a
make[4]: Leaving directory '/opt/epics/synApps_6_3/support/quadEM-master/quadEMApp/nslsSrc/O.linux-x86_64'
make[3]: Leaving directory '/opt/epics/synApps_6_3/support/quadEM-master/quadEMApp/nslsSrc'
make -C ./FX4Src install
make[3]: Entering directory '/opt/epics/synApps_6_3/support/quadEM-master/quadEMApp/FX4Src'
mkdir -p O.Common
make[4]: Entering directory '/opt/epics/synApps_6_3/support/quadEM-master/quadEMApp/FX4Src/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -MM -MF IXWebSocketTransport.d  ../ixwebsocket/IXWebSocketTransport.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -MM -MF IXWebSocketServer.d  ../ixwebsocket/IXWebSocketServer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -MM -MF IXWebSocketProxyServer.d  ../ixwebsocket/IXWebSocketProxyServer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -MM -MF IXWebSocketPerMessageDeflateOptions.d  ../ixwebsocket/IXWebSocketPerMessageDeflateOptions.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -MM -MF IXWebSocketPerMessageDeflate.d  ../ixwebsocket/IXWebSocketPerMessageDeflate.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -MM -MF IXWebSocketPerMessageDeflateCodec.d  ../ixwebsocket/IXWebSocketPerMessageDeflateCodec.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -MM -MF IXWebSocketHttpHeaders.d  ../ixwebsocket/IXWebSocketHttpHeaders.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -MM -MF IXWebSocketHandshake.d  ../ixwebsocket/IXWebSocketHandshake.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -MM -MF IXWebSocket.d  ../ixwebsocket/IXWebSocket.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -MM -MF IXWebSocketCloseConstants.d  ../ixwebsocket/IXWebSocketCloseConstants.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -MM -MF IXUuid.d  ../ixwebsocket/IXUuid.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -MM -MF IXUserAgent.d  ../ixwebsocket/IXUserAgent.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -MM -MF IXUrlParser.d  ../ixwebsocket/IXUrlParser.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -MM -MF IXUdpSocket.d  ../ixwebsocket/IXUdpSocket.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -MM -MF IXStrCaseCompare.d  ../ixwebsocket/IXStrCaseCompare.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -MM -MF IXSocketTLSOptions.d  ../ixwebsocket/IXSocketTLSOptions.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -MM -MF IXSocketServer.d  ../ixwebsocket/IXSocketServer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -MM -MF IXSocketOpenSSL.d  ../ixwebsocket/IXSocketOpenSSL.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -MM -MF IXSocketMbedTLS.d  ../ixwebsocket/IXSocketMbedTLS.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -MM -MF IXSocketFactory.d  ../ixwebsocket/IXSocketFactory.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -MM -MF IXSocket.d  ../ixwebsocket/IXSocket.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -MM -MF IXSocketConnect.d  ../ixwebsocket/IXSocketConnect.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -MM -MF IXSocketAppleSSL.d  ../ixwebsocket/IXSocketAppleSSL.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -MM -MF IXSetThreadName.d  ../ixwebsocket/IXSetThreadName.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -MM -MF IXSelectInterruptPipe.d  ../ixwebsocket/IXSelectInterruptPipe.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -MM -MF IXSelectInterruptFactory.d  ../ixwebsocket/IXSelectInterruptFactory.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -MM -MF IXSelectInterruptEvent.d  ../ixwebsocket/IXSelectInterruptEvent.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -MM -MF IXSelectInterrupt.d  ../ixwebsocket/IXSelectInterrupt.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -MM -MF IXNetSystem.d  ../ixwebsocket/IXNetSystem.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -MM -MF IXHttpServer.d  ../ixwebsocket/IXHttpServer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -MM -MF IXHttp.d  ../ixwebsocket/IXHttp.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -MM -MF IXHttpClient.d  ../ixwebsocket/IXHttpClient.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -MM -MF IXGzipCodec.d  ../ixwebsocket/IXGzipCodec.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -MM -MF IXExponentialBackoff.d  ../ixwebsocket/IXExponentialBackoff.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -MM -MF IXDNSLookup.d  ../ixwebsocket/IXDNSLookup.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -MM -MF IXConnectionState.d  ../ixwebsocket/IXConnectionState.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -MM -MF IXCancellationRequest.d  ../ixwebsocket/IXCancellationRequest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -MM -MF IXBench.d  ../ixwebsocket/IXBench.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -MM -MF drvFX4.d  ../drvFX4.cpp
In file included from ../msgpack-c/include/msgpack/v1/pack_decl.hpp:15,
                 from ../msgpack-c/include/msgpack/pack_decl.hpp:13,
                 from ../msgpack-c/include/msgpack/pack.hpp:13,
                 from ../msgpack-c/include/msgpack/v1/object_decl.hpp:14,
                 from ../msgpack-c/include/msgpack/object_decl.hpp:14,
                 from ../msgpack-c/include/msgpack/object.hpp:13,
                 from ../msgpack-c/include/msgpack.hpp:10,
                 from ../drvFX4.h:24,
                 from ../drvFX4.cpp:35:
../msgpack-c/include/msgpack/sysdep.hpp:168:5: error: #error msgpack-c supports only big endian and little endian
  168 | #   error msgpack-c supports only big endian and little endian
../msgpack-c/include/msgpack/v1/pack_decl.hpp:82:2: error: #error msgpack-c supports only big endian and little endian
   82 | #error msgpack-c supports only big endian and little endian
In file included from ../msgpack-c/include/msgpack/pack_decl.hpp:14:
../msgpack-c/include/msgpack/v2/pack_decl.hpp:47:2: error: #error msgpack-c supports only big endian and little endian
   47 | #error msgpack-c supports only big endian and little endian
In file included from ../msgpack-c/include/msgpack/pack_decl.hpp:15:
../msgpack-c/include/msgpack/v3/pack_decl.hpp:46:2: error: #error msgpack-c supports only big endian and little endian
   46 | #error msgpack-c supports only big endian and little endian
In file included from ../msgpack-c/include/msgpack/pack.hpp:15:
../msgpack-c/include/msgpack/v1/pack.hpp:717:2: error: #error msgpack-c supports only big endian and little endian
  717 | #error msgpack-c supports only big endian and little endian
Installing dbd file ../../../dbd/drvFX4.dbd
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../ixwebsocket -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/opt/epics/synApps_6_3/support/quadEM-master/include      -I/opt/epics/synApps_6_3/support/asyn-R4-46/include  -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps_6_3/support/autosave-master/include/os/Linux -I/opt/epics/synApps_6_3/support/autosave-master/include   -I/opt/epics/synApps_6_3/support/busy-R1-7-4/include   -I/opt/epics/synApps_6_3/support/calc-master/include   -I/opt/epics/synApps_6_3/support/sequencer-main/include   -I/opt/epics/synApps_6_3/support/sscan-R2-12/include  -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include/os/Linux -I/opt/epics/synApps_6_3/support/iocStats-3-1-16/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include    -I../ixwebsocket/include -I../msgpack-c/include    -c ../drvFX4.cpp
../msgpack-c/include/msgpack/sysdep.hpp:102:10: fatal error: boost/predef/other/endian.h: No such file or directory
  102 | #include <boost/predef/other/endian.h>
compilation terminated.
make[4]: *** [/opt/epics/base/configure/RULES_BUILD:268: drvFX4.o] Error 1
make[4]: Leaving directory '/opt/epics/synApps_6_3/support/quadEM-master/quadEMApp/FX4Src/O.linux-x86_64'
make[3]: *** [/opt/epics/base/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[3]: Leaving directory '/opt/epics/synApps_6_3/support/quadEM-master/quadEMApp/FX4Src'
make[2]: *** [/opt/epics/base/configure/RULES_DIRS:85: FX4Src.install] Error 2
make[2]: Leaving directory '/opt/epics/synApps_6_3/support/quadEM-master/quadEMApp'
make[1]: *** [/opt/epics/base/configure/RULES_DIRS:85: quadEMApp.install] Error 2
make[1]: Leaving directory '/opt/epics/synApps_6_3/support/quadEM-master'
make: *** [/opt/epics/base/configure/RULES_DIRS:85: /opt/epics/synApps_6_3/support/quadEM-master.install] Error 2
Re: Error building quadEM Soliday, Robert T. via Tech-talk
Prev: Re: Display Images on .bob using DBWR Kasemir, Kay via Tech-talk
Next: Re: Error building quadEM Soliday, Robert T. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Prev: Re: PVA Gateway performance with large image arrays Michael Davidsaver via Tech-talk
ANJ, 10 Aug 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
