On Mon, 5 Oct 2026 at 12:56, Rea Domitrović <rea.domitrovic at irb.hr> wrote:
Ok, that makes a lot of sense now. Here's a general design idea - one of many possibilities, just to show how a typical EPICS database design could look like Two low level records for controlling the two mux channels (probably mbbo = enum type). Two low-level input records (ai) that read the picometer data. Two dfanout records (one for each low-level input) to demultiplex the data inside the EPICS database into... Four high-level input records (ai), one for each accelerator. Two combinations of calcout and seq record that automate the setup: The calcout is creating bit patterns for the seq, and the seq (in bitset mode) does the sequencing: put the dfanout in idle, switch the mux box, wait a bit, put the dfanout to the right high-level input. If you want automation, have the calcout flip back and forth. Like Lego pieces that can do interesting things when put together correctly. Cheers, ~Ralph
| ANJ, 06 Oct 2026 |
Home
News
About
Talk
Base
Modules
Extensions
