2012  <20132014  2015  2016  2017  2018  2019  Index 2012  <20132014  2015  2016  2017  2018  2019
Subject: RE: EPICS QT 2.3
To: Zenon Szalata <[email protected]>, Andrew Rhyder <[email protected]>, "[email protected]" <[email protected]>, "Dunning, Michael" <[email protected]>
Date: Wed, 20 Mar 2013 15:45:33 -0700
> I tried to use the epicsQT push button and set it up as a toggle and
> something is escaping me because I can't get it to work. When I click
> on it, a dialog pops up telling me that it failed to write a string "0",
> or something like that. Obviously I am not setting it up correctly.
You may be using a push button with local enumeration....   and a altReadbackVariable.
It appears that local enumeration is used on the BOTH the control and readback variable.
Try to set local enumeration to 0:1,1:0
Enjoy,
Emmanuel
EPICS QT 2.3 Zenon Szalata
Prev: caQtDM Mezger Anton Christian
Next: EPICS Qt Framework SVN repository Ricardo Fernandes
Index: 2012  <20132014  2015  2016  2017  2018  2019
Prev: EPICS QT 2.3 Zenon Szalata
Next: caQtDM Mezger Anton Christian
ANJ, 02 Apr 2013 · Home · News · About · Talk · Base · Modules · Extensions ·
