<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: AR data file format
Date: Mon, 4 Apr 94 10:38:41 MDT
> From [email protected] Mon Apr  4 09:09:09 1994
> From: greene%[email protected]
> To: [email protected]
> Subject: AR data file format
> Content-Length: 103
> X-Lines: 5
> Is the data file format for AR described anywhere?
> Greg Greene
> KineticSystems Corp
> (303) 220-7455 x13
Unfortunately, there are NO documents describing the archiver file formats.
My first suggestion is to look at the source code in the following
locations under .../epics/r3.X/share/src/  :
1. epicsH/arChanIO.h
	This file provides the most information on the format of binary
	archiver files.
2. libCom/arChanIO.c
3. libCom/arAccessLib.c
	Look at the "arCFChanWrite" routines
4. epicsH/arAcessLib.h
5. libCom/bfSubr.c
6. epicsH/bfDefs
7. libCom/sydSubrSSF.c
	This tells how to read the ascii archive files
8. ar/arCFChanTest.c
	This gives an example of how to write data to a binary
	format file.
If you are simply interested in reading archived files, it is best done
through the "syd..." routines (not sydCF or sydSSF). This gives the
user access to both types of archiver files using only 1 set of routines.
Good luck,
Carl Timmer, LANL
Prev: AR data file format greene%denali . UUCP
Next: CVS and unbundling mrk
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
