<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: MV167s and the 712M module
Date: Fri, 22 Apr 94 12:40:17 CDT
At APS found that the Tracewell crate did not provide proper cooling to
slots 1 - 3. We also did not like the fact that the power supplys and
fans were not easily field replaceable. We subsequently had Mupac
redesign the crate to provide the proper cooling and to allow field
replacement of the fans and the power supply. In addition the Mupac has
additional cooling for the power supply is provided by a power supply
top mounted fan and a connector (DB9) is provided for the remote
monitoring of the crate's power supply voltages.
The same power supply (TODD) is resident in both the Tracewell and the MUPAC.
Air flow measurements in  MUPAC and  Tracewell VME crates.  You can draw
your own conclusions from the data listed below..
slot	Tracewell		       /	     Mupac
___________________________________________________________________________
posn:	1           2          3       /       1          2         3
1.	150f/m     40f/m     40f/m     /      2700f/m     3200f/m   3700f/m
posn:   4           5          6       /       4          5         6
2.      400        500       325       /      3500        3500      4500
posn:   7           8          9       /       7          8         9
3.      4000       2000      3500      /      3500        2000      1500
posn:   10          11         12      /       10         11        12
4.      3600       800       2500      /      4000        1250      2500
posn:   13          14         15      /       13         14        15
5.      3600       800       2500      /      3800        1700      2500
posn:   16          17         18      /       16         17        18
6.      4000       3000      4500      /      3000       2000      1500
posn:   19          20         21      /       19         20        21
7.      4000       4500      3500      /      1700       1100      1500
The part number for the Mupac crates is 5099KDM20FK-XXX
We have two hardware module that replace the 712M.
1. System Monitor Module
This board is meant to replace the MVME712 Transition Modules as well
as provide additional features that will facilitate in monitoring the
status of the IOCs.
In addition, EPICS device support has been written for the board.
This board provides:
- Serial Console Port
- AUI connector for ethernet
- VME interface to read and write registers as well as generate
interrupts
- Status Link that transmits the status of the VME crate to a neighbor
crate
	This status includes:
	- state of the watchdog timer
	- temperature threshold
	- CPU status
	- CPU Run Status
	- Voltage monitor, 5V
	- Voltage monitor, +-12V
	- CPU fail status
- Remote VME reset of backplane, by monitoring Serial Port
- Digital I/O (8 outputs, 4 inputs), able to generate an interrupt to CPU
- Temperatue Monitor (5C increments)
- Voltage Monitor for 5V and +-12V
- Watchdog Timer
2. Simple Interface:
- Serial Console Port (copper of fiber)
Prev: MV167s and the 712M module Carl Dickey
Next: Re: MV167s and the 712M module winans
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
