Subject: |
applications that use channel access |
[email protected] (Jeff Hill) |
Date: |
Tue, 26 Apr 94 13:19:00 MDT |
Hello all,
This message is directed to the authors or maintainers of application
software that uses the channel access client library.
>From the channel access client library callable interface it is possible
to specify that a connection is to be made to a named channel and
to __simultaneously__ fetch the value of the channel. It is the perception
of the author that this is a very rarely used feature of channel access.
I am considering eliminating this feature of channel access from future
releases of EPICS possibly as early as release 3.12. I will preserve
existing functionality however I will preclude performing both operations
from the same request. After the change applications will be forced
to wait for a channel to connect prior to fetching its value.
I am sending this message to survey the EPICS community
concerning the potential impact of this change. Please send a reply to
this message if you fear that the change will cause a disruption at
your site.
Your application is using this feature of channel access if __all__ of
the following are true.
o your application calls one of ca_build_and connect(),
ca_array_build(), or ca_build_channel()
o your application specifies an external type other than TYPENOTCONN
to one of the calls above
o your application supplies a non-zero pointer specifying a location
where the channel's value is to be written to one of the calls above.
o your application specifies an array element count other than zero to
Jeff
______________________________________________________________________
Jeffrey O. Hill Internet [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos, NM USA 87545 FAX 505 665 5107
Re: Tracewell crates mcgehee
Re: applications that use channel access John R. Winans
<1994>
2025
2026
sysBusTas problem Robert Belshe
<1994>
2025
2026
