<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: GPIB driver
Date: Wed, 4 May 94 16:03:55 MDT
To those of you doing GPIB:
There is a problem that surfaced recently concerning the NI 1014D
gpib board. When doing DMA data reads (i.e. reading waveforms
from a Tektronix digitzer), bus errors were mysteriously generated.
It turns out that some changes to the "drvGpib.c" code would be advisable.
In the "niPhysIo" routine, there are two lines,
  b->ch0.ccr = D_SRT;
  b->imr2 = w_imr2;	/* this must be done last */
between which there should be a time delay. Apparently, the gpib board is
in occasional violation of the VME standard and the attempt to write to
interrupt mask register 2 (I believe) fails. I have a fix which also allows
one to fix & debug the situation. If interested, send me email and I'll send a
revised copy of "drvGpib.c" .
This correction will be included into the next release of EPICS.
Carl Timmer
Prev: Re: Portable CA server? winans
Next: AVME9440 Ned Arnold
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
