<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Archiving identical values
Date: Wed, 11 May 94 13:41:58 -0500
Under gtacs (the precurser of epics) this was true. Archive Monitors were raised on >=
but under epics on >. Actually under gtacs this switch at least once.
Epics ended up usng >=. Thus you must set ADEL to a negative number to force
monitors even if there is no change.
Marty Kraimer
> I am having a problem getting the archiver to archive AI records when
> the value doesn't change.  According to the documentation, as long as
> ADEL is 0, then AR should archive *all* records, regardless of values.
> This is not the case here.  I'm using defaults for all fields except for
> SCAN, DTYP, INP, and HOPR so my AI records are pretty basic.  Here's
> my archive request file:
> DESC:	Test archive for throughput and data validity
> ACT:   	demand
> INACT: 	demand
> SAMPLE:	monitor
> OUTPUT:	chan:bin
> %endHeader%
> ai1
> ai2
> ai3
> ai4
> AR displays "no_data" for those values which haven't changed.  I monitored
> the actual data and verified that "no_data" occurs only when the data
> hasn't changed between samples.  Any ideas?
> Greg Greene
Prev: Archiving identical values greene%denali . UUCP
Next: Limits on CA message size? mcgehee
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
