<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: PV name length limit
Date: Tue, 17 May 1994 08:16:30 -0700
	Are there any plans to increase the current 28 character limit on
record names?
	Our rational for asking is this: the Gemini control system has four
major components -
	1) TCS (Telescope Control System) - beam control
	2) ICS (Instrument Control System) - detector control
	3) DHS (Data Handling (and Reduction) System) - data management
	4) OCS (Observatory Control System) - highlevel sequencing, preprogrammed
	observing management.
Of these the TCS and ICS are clearly IOC-based. The issue here is that the OCS
lives in a world of high-level configurations whose directives are phrased in
fairly human readable terms and that we would like to have all four systems
use a common name-space. We realize that it is possible to set up a translation
between the name-space used by the OCS and that used by the IOC-based systems
but would prefer a consistent naming convention - and not have to worry about
record name lengths!
	As a general issue on system architecture - I would guess that most
experimental physics control systems would use a similar system breakdown -
except in more 'engineering mode' cases where the OCS would be absent.
	Does anyone else use the equivalent of the OCS?
Peregrine
Prev: Frame to HTML Pratik Gupta
Next: Re: PV name length limit Tim Mooney
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
