Subject: |
Re: BITBUS and PC's |
[email protected] (Jeff Hill) |
Date: |
Thu, 9 Jun 94 15:54:39 MDT |
> > Any comments about using PC's?
> Every week I hear from someone wanting to use a PC as an IOC, either to
> preserve an existing hardware/software investment, or to take advantage
> of EISA boards that are cheaper than the equivalent VME board or that
> have no equivalent on an EPICS supported platform. In fact, several
> APS-affiliated developers are talking about limiting their use of EPICS
> at APS to those features they can mimic on PC's at their home labs, so
> they can run approximately the same software in both places (a very big
> deal to many developers here).
> Scary? It reduces EPICS, in such applications, to small pieces of the
> channel-access library. But I can't argue with someone solving their
> group's problems the only way they can.
> What would it cost to port EPICS to VxWorks on a PC?
The port would require changes to the CA server to swap the bytes in
each of the structures in db_access.h. Part of this code already
exists in the VAX CA client library. There is also some byte swapping
in the socket interface and the CA protocol that would need to be
handled. You would also need to load your database in ASCII. If you wish
to use existing EPICS drivers then be sure to pad uncertainty into the
schedule for potential memory mapping problems and other CPU dependencies.
The above assumes that you will be using a VME SBC PC. If it
is to be an EISA IOC then there will be some drivers to write.
When WRS produced their first board support package for the i960
they were significantly behind schedule producing a working
system.
Jeff
______________________________________________________________________
Jeffrey O. Hill Internet [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos, NM USA 87545 FAX 505 665 5107
vxi device support/record support parameters cleaves%mickey.UUCP%denali.UUCP
Re: BITBUS and PC's Mark Rivers
<1994>
2025
2026
Re: BITBUS and PC's Tim Mooney
<1994>
2025
2026
