<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: DSP
Date: Wed, 15 Jun 1994 17:09:14 -0700
Jim,
In the near future I will be integrating a Spectrum DSP board into
an EPICS control system.  I may (or may not) make heavy use of
sequencers to do most of the work.  However, I am curious of your
implementation with the Pentek board: 1) how does the vxWorks interrupt
"alert" record processing that something needs to be done, and 2) what
kinds of records are you using?  How do you connect those records to the
data coming through the system?  Is it using pvPut's & pvGets?  I also
would like to know if you have any ideas for record types or modifications
that would enhance the support of DSP cards.  It seems to me that each
application would be too unique to generalize, but the results could be
put into waveforms, etc.
Prev: Re: DSP edward moler
Next: Re: vxWorks Carl W. Cork
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: OMS VME-8 motor controllers: PAL upgrades Bob Dalesio
