<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Need to use a board in various configurations.
Date: Mon, 11 Jul 94 13:25:25 -0500
>It turns out that this isn't really a very good solution - it would be
>much better if it were possible to allocate resources in a more flexible
>manner.
Lately, I have been writing drivers that require user configuration.
So many features and options that just can't be represented by the DTYP
field alone.  I use a function that in your case would have a name
like VmiVme2534Config().  It would take parms used to cinfigure the
board.  For your situation, I would have the following parameters:
1) The board link number to configure.
2) The board's base address is what ever address space it appears.
3) An IRQ vector and associated level.
4) A bitmask that describes the direction of data flow.
An alternate solution would be to leave the thing uninitalized and wait
for the record init phase to decide what to do.  You COULD dynamically
assign the data direction based on what the records are configured for.
This is how the GPIB device support works with respect to knowing what
devic addresses are used are attached to what links.
Ahhh... I now see Ned thinks highly of the dynamic config idea too.
--John
Prev: Re: Need to use a board in various configurations. Ned Arnold
Next: Re: Need to use a board in various configurations. mrk
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
