<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CaMath
Date: Wed, 13 Jul 94 14:40:18 CDT
The setup requirement in CaMath documentation is out of date.
I will modify it as early as possible.
CaMath is unbundled from the  EPICS system area since EPICS
3.11.6 release. CaMath  becomes an add_on tool, now it resides
in EPICS_ADD_ON/bin.  The  setupmath  now resides in
EPICS_ADD_ON/bin too.
The template files  CaMath.m  and caDef.m resides in
EPICS_ADD_ON/doc directory.
This new version of  setupmath  requires that the environment
variable ADD_ON been defined first. It should be set same as
the path to the add_on directory ( e.g. /net/phebos/epics/add_on ).
The simple setup procedure is given below:
mkdir math
cd math
setenv ADD_ON /net/phebos/epics/add_on
setupmath
math						| run mathatica
Ben-chin Cha
Prev: CaMath greene%denali.UUCP
Next: Asynchronous Momentary Binary Output Bug mrk
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
