<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Asynchronous Momentary Binary Output Bug
Date: Fri, 15 Jul 94 10:28:37 -0500
>The fix is to ha ve the callback routine (after locking) check to see
>if the record is active. If it is it just reschedules itself again. It
>does this until it finds the record not active and then sets the value
>to 0 and calls dbProcess.
*I* would say that the /fix/ would be to treat async and sync record
processing the SAME WAY... leave the record locked and inaccessable
from start to finish.  The fix you sugest is only a patch for *this*
single problem that async processing presents.
The async device support that I have written and have seen written don't
check the record values again during an async completion phase.
Therefore if someone sneaks a value into the record during the PACT=1
idle time... it will go unnoticed... which is exactly what is causing
the problem your problem as well.
I would prefer that the solution to the momentary binary output problem
also be applicable to the general integrity problem observed in ALL
fields of a record when it is processed asynchronously.
The ability for a put (or a get) to operate on a PACT=1 record has
been a disaster waiting to happen since day 1.  I have no design ideas
on an overall solution at this time.  Only a desire to see this
annoyance go away.
If anyone has any ideas about this, I would like to hear them.  I am
sure that everyone would go along with a grand repair to this if we
only had a _reasonable_ idea on how to do it.
--John
Prev: Asynchronous Momentary Binary Output Bug mrk
Next: Re: Asynchronous Momentary Binary Output Bug Tim Mooney
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
