<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Re: Asynchronous Momentary Binary Output Bug
Date: Fri, 15 Jul 94 12:31:20 -0500
> > 2a)The value 1 is written to the record and the record starts  processing
> >    Record processing calls device support which queues a request to the device
> >    and tells record support that it has started asyn processing.
> >    The 1st phase of processing completes. Record is unlocked but active.
> If PACT is TRUE via step 1, why does this record process when a value is
> written to it here?
PACT is no longer TRUE. Remember that honoring the HIGH field is done via a
completely new request for record processing. The PACT field is only kept
TRUE between asyn start and asyn completion.
Marty Kraimer
Prev: Re: Asynchronous Momentary Binary Output Bug Tim Mooney
Next: Re: Re: Asynchronous Momentary Binary Output Bug mrk
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
