Again... sorry for any duplicates.
-- FYI --
Motorola has a mailing list that should be of interest to most of those
on this list. They are concerned about sending into an exploder since
it is essentially a commercial use of email and they wish to keep a eye
on where THEY are sending things.
I have enclosed the first (only) note from this list below. To
subscribe to the list, send a note to their listserver as described
below.
- --John Winans
Volume 1 Number 1
*********************** MCG AboveBoard Newsletter ***********************
Hello MCG customers,
This is the first edition of the "MCG AboveBoard" customer newsletter.
The newsletter is a product of the Motorola Computer Group's Central
Area Sales organization and is directed towards MCG's VMEbus board level
customers. With this newsletter we hope to:
* Focus on technical content
* Brief (1 to 2 pages) with no fancy Multi-Media Attachments
* Monthly editions (maybe more?)
* Provide archive & retrieval of past newsletters
For this first edition I've collected Email addresses from many of
our major customers. By just sending THIS letter I feel guilty of
polluting your networks with electronic junk mail so I've set this
newsletter up so that it will be available on a subscription basis.
I already apologize if you're not interested.
To continue getting updates updates you can send a mail message to
"[email protected]" with the following message body.
subscribe aboveboard <your_email_address>
Bob Galbreath
Systems Engineer
*** Table of Contents ***
1. VMEchip2 Problem
2. MVME147 Ethernet Controller Change
3. MVME162 Flash Memory Alert
4. New versions of the MVME167 and MVME187
5. New version of the MVME166
6. Some End of Life Notifications
7. MVME1603 & MVME1604 Announcements
8. MCG Contacts
1. VMEchip2 Problem
A problem has been identified with the VMEchip2 and its interaction
with the VMEbus backplane. In heavily loaded VMEbus backplanes,
there may be a glitch at the end of Data Strobes (DS0*/DS1*) as the
Data Strobes are negated due to backplane reflection timing relative
to tri-state timing of onboard signal ABOUT (which controls the
DS0*/DS1* drivers). This signal glitch may cause problems with
boards that are sensitive to it. The fix required is to delay the
tri-state control signal ABOUT. For existing boards, a 1000PF SMD
capacitor will be added between ABOUT and Ground. For MVME162-0xx
(01-W3884BxxA), MVME162-2xx (01-W3866BxxA), MVME166-xxx
(01-W3834Bxxy), MVME167-xxxA (01-W3826Bxxy), and MVME187-xxxA
(01-W3827Bxxy) that use the 160G mask of VMEchip2 (51-W6280B02), the
easiest way to implement the fix is to add a 1000PF SMD capacitor
that can be added between Pin P2 and Pin N1 of the VMEchip2 on the
secondary side (back side).
This fix has been implemented for new builds of product. Customer's
experiencing problems with the Data Strobe and need the fix added
to their boards should contact their local Systems Engineer or
Salesperson to make arrangements for the fix. This is covered under
warranty.
NOTE: Customer's who implement this fix themselves will
void the warranty of their board.
Please note that this change effects only boards using 160G VMEchip2.
We are also expediting the MVME166/167/187LGA (See Section 4 below)
programs to phase out the current MVME167/167/187 boards. For respins,
we used spare 25NS delaylines instead of the 1000PF capacitor. The
delay will be added to both ABOUT (DS0*/DS1* tri-state control) and
STROBEN (AS* tri-statecontrol).
The AM7990JC LANCE Ethernet controller used on the MVME147 series has
been discontinued. It will be replaced the the AM79C90JC. This part
is downward compatible so there should be no hardware or software
migration issues. MVME147's with the new devices are expected to
start shipment in July.
The MVME162 family has been experiencing failures related to FLASH
memory. Most of these were due to over-erasure of the FLASH devices.
The problem has been corrected with version 2.1 of the MVME162Bug.
An update has been made the MVME167 and MVME187 to upgrade the
VMEbus chip to a ball grid array version. The die is still the
same so there should be no functional change. This does, however
impact the look and feel of the board. Because of that there
are new marketing part numbers.
Old Number New Number
MVME167-xxxA MVME167-xxxB
MVME187-xxxA MVME187-xxxB
An update has been made the MVME166 to upgrade the VMEbus chip to a
ball grid array version. Also included is a VSB chip with new
packaging as well as the new 166Bug revision 2.2.
MVME166-xxx MVME166-xxxA
This is by no means a comprehensive list. Please consult your
salesperson for a complete list as well as MCG's policies
regarding EOL'd equipment.
LOE => Last Order Entry
LCS => Last Customer Scheduled Ship
LFS => Last Field Service Support
Product LOE LCS LFS Replaced by
MVME167-xxxA 9/31/94 12/31/94 12/31/99 MVME167-xxxB
MVME187-xxxA 9/31/94 12/31/94 12/31/99 MVME187-xxxB
MVME166-xxx 6/31/94 9/31/94 9/31/99 MVME166-xxxA
We recently announced our first two PowerPC-based VME boards.
Please consult your MCG salesperson for price and availability
* 66MHz PowerPC 603 or 100MHz PowerPC 604
* 32-bit PCI local bus with PCI Mezzanine Card Extension
* 8 to 128 MB DRAM replaceable modules
* Ethernet
* 16-bit SCSI-2
* SVGA Graphics
* Mouse and keyboard
* Serial and Parallel I/O
* VME64 Interface
* 5 year warranty.
8. MCG Contacts
Ken Curran Mike Mullany
District Sales Manager District Sales Manager
(708) 576-8874 (708) 576-7831
[email protected] [email protected]
Bob Galbreath Steve Wesoloski
Systems Engineer Systems Engineer
(708) 576-0356 (612) 932-1530
On the ordering of mvme167 boards winans
Xy240 Chris Mayer
<1994>
2025
2026
mvme167 errata winans
Xy240 Chris Mayer
<1994>
2025
2026
