Subject: |
Re: a friend in need |
[email protected] (Jim B. Kowalkowski) |
Date: |
Tue, 23 Aug 1994 14:16:00 -0600 |
>From [email protected] Tue Aug 23 13:42:10 1994
>From: Fred Carter <[email protected]>
>Subject: a friend in need
>A friend writes:
>The driver I am looking for is for a
>PENTEK Model 4261 10 MHz 12-bit A/D board (i.e. waveform digitizer)
>I also need a driver for a BIT3 card; this card interfaces the SUN's
>S-BUS to the VME.
>It is urgent that I find out if it exists, so that I don't have
>to recreate the wheel.
>If anyone has information reguarding this matter,
>he is not listed on the list_server. However, his e-mail
>address is as follows:
> [email protected] <Ernest Williams>
>Thanks a bunch,
I just finished some EPICS device support for the PENTEK Model 4261a
10 MHz 12-bit A/D board. My support uses the waveform record and currently
runs using the external trigger and I/O interrupt scanning. When the
waveform record initializes, the 4261a is programmed to take samples using
the size of the array (in the waveform record). The external trigger
causes the 4261a to start taking samples, when the correct amount
of samples is taken, the 4261a interrupts the mvme167 (vxWorks) and does
the waveform record processing.
The support I have can easily be expanded to use other modes of data
collection such as period scanning instead of external trigger.
Send me email if you want more information about it.
Jim Kowalkowski
Argonne National Laboratory
Advanced Photon Source
708/252-9410
[email protected]
[email protected]
a friend in need Fred Carter
APS Event Hardware mcgehee
<1994>
2025
2026
RE: a friend in need Gabor Csuka, DESY - Germany
<1994>
2025
2026
