<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: VMIC 4514 board.
Date: Mon, 7 Nov 94 16:28:27 HST
Has anyone written any device and driver support for the VMIC 4514
board?
If not, has anyone any suggestions on a good driver to use as a
template? It has 16 analog inputs and 16 analog outputs. The inputs can
be set to scan, in which case all the I/O values are always available
in registers. However, if you perform the reads on request you have to
set the read up, wait some time (~5 milliseconds) and then poll - it is
a bit nasty since there is no interrupt on ADC completion.
Nick Rees
Joint Astronomy Centre                    Ph:       +1 (808) 961-3756
660 N. Aohoku Place                       Fax:      +1 (808) 961-6516
Hilo, HI.  96720                          Internet: [email protected]
Prev: Re: CALC record Tim Mooney
Next: Re: CAMAC watson
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Regarding Duke's FEL Laboratory Carl Dickey
