<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Lock sets for read access
Date: Wed, 30 Nov 94 12:36:37 CST
re...
> From [email protected] Tue Nov 22 17:53:05 1994
> > From [email protected] Tue Nov 22 08:35 CST 1994
> > So, my thoughts are:
> > 1) Do lock sets inhibit read access as well as write and process access?
> Starting with 3.12 reads from outside the database, i.e. from channel access,
> lock. Previously this was not true. Note however that each individual read
> locks. Thus if you have a series of ca_gets you will not get what you want.
Could you clarify that?  If a read is attempted while a record is locked
because a member of its lock set is processing, does the read pend until
the lock goes away?
Tim Mooney
Prev: Re: Analog input record offsets Tim Mooney
Next: Re: Lock sets for read access Marty Kraimer
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Lock sets for read access Marty Kraimer
