<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MVME162's for remote I/O
Date: Thu, 01 Dec 94 11:46:12 -0600
A 162 can be used as an IOC in standalone mode on an ethernet, yes.
You simply order the 162 version of the vxWorks BSP, add power, and
you are on line without even needing a VME chassis.  If fact, Motorola
sells the 162's at a discount price if you order them w/o a VME
interface.  (IMHO, they would make a pretty nifty replacement for the
BUG devices we have been using here at the APS.)
For your I/O you would (obviously) want to use some IP boards.  There
are not any official EPICS drivers for them as far as I know.  DESY
has been doing work in that area.  And there is always talk of them in
the c.o.v group on usenet.
We (APS) have been working on some code that allows a host to treat the
mv162 and its IP cards as a intelligent I/O device.  That is, EPICS
would run on a host processor in the VME crate (as it always has) and
the 162 sits aside it as a really smart device.  The CPU on the 162
board only runs the low level driver codes.  We have been calling the
low level driver code part HiDEOS.  You may place as many of the 162
cards in the crate as you have room.
At this moment, the APS has some A/D and serial HiDEOS drivers running
in this configuration.
--John
Prev: MVME162's for remote I/O John Maclean
Next: Re: MVME162's for remote I/O Matthias Clausen DESY -MKV2/KRYK-
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
