Subject: |
Re: VxGDB question |
[email protected] (Jeff Hill) |
Date: |
Tue, 3 Jan 95 10:36:58 MST |
> I want to use VxGDB to print the contents of a pointer which
> points to a valid VXI memory location for a specific card. I have found
> that I can't use the "print *" option - I get the following error:
> (vxgdb) print ptr
> $1 = (int *) 0x20000000
> (vxgdb) print *ptr
> ptrace: Bad address.
> Cannot read memory: address 0x20000000 out of bounds.
> (vxgdb)
> This appears to be a limitation with ptrace(). I need to
> know *how* I can print the contents of pointers to VXI memory since I
> apparently can't do it with "print *". I would prefer using VxGDB to
> do this is possible. Any suggestions?
I suspect that your troubles result from VxGDB's using "ptr" as
an "(int32_t *)" when most register based VXI devices accept
"(int16_t *)" access only.
On the 68k:
int16_t maps to C type short
int32_t maps to C types int and long
Jeff
______________________________________________________________________
Jeffrey O. Hill Internet [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos, NM USA 87545 FAX 505 665 5107
vxWorks version 5.1.1 winans
<1995>
2025
2026
<1995>
2025
2026
