1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Bug in DM using long records?
Date: Thu, 5 Jan 1995 21:21:12 GMT
Can anyone confirm the following behaviour of DM?  I think it is be a bug, and a
fairly old one at that:
I have a longin record, Soft record type, running in an IOC running 3.12Beta1,
but I suspect the IOC release is irrelevant.
I have a display created using EDD (3.12Beta1), with a Valuator and an Indicator
both connected to the above longin record.
When I run up the display under DM, the limits on both the Valuator and
Indicator are not the same as the High and Low Operating range of the record.
If I move the valuator, the Indicator does not move, although it is obviously
being refreshed.  However I can use cau to monitor the record and it shows it
changing correctly to the Valuator settings. If I ask the DM window to refresh,
the Valuator jumps to a seeming random value, although cau does not show the
record changing.
I have checked this using DM from 3.11.4, and a similar behaviour occurs.
- Andrew
          ,_}\_.        Andrew Johnson, Technology Division
         /      \       Royal Greenwich Observatory
~~~~~~~~| ,--/;. )~~~~  Madingley Road, Cambridge, UK
    .,  |/  (/  U       Phone: +44 (0)1223 374823
  .`., /_\ . .          Email: [email protected]
     wwWWWww'           WWW: http://cast0.ast.cam.ac.uk/~anj/
Prev: Re: Epics release 3.12.Beta3 - apology watson
Next: Re: Bug in DM using long records? Carl Timmer
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Epics release 3.12.Beta3 - apology Gabor Csuka, DESY - Germany
