1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Making releases
Date: Tue, 14 Feb 95 14:13:20 PST
Tony Cox writes:
> PGP has a more secure method for doing what we want. You encrypt the file for
> multiple users like this:-
> 	pgp -e R3.12.0.Tar Bob Chip Tony Alan Janet Uncle-Tom-Cobbly ...
First, a few notes here for collaborators not 'up' on this pgp-stuff:
Pgp -e uses public key encryption for a list of recipients.  It actually
encrypts the message using private-key (IDEA algorithm) based encryption,
and then it uses public-key encryption to encrypt the random private key that
it selected for this particular message.  Thus any intended recipient can
decrypt using his/her private key.  Pgp automates all this detail so it
is easy to use.
Using public key encryption is not exactly 'more secure', but different
in the sense of key management.
What Tony is proposing is a good way of handling the problem as well, let's
take a look at the mechanics of each approach:
Private Key System:
  Distributor:
    initial preparation:
    1.  setup ftp-only account with password
    2.  get and install pgp
    3.  tar up the release
    4.  choose passphrase and encrypt
    5.  copy into account
    6.  notify & reveal account/passwd/file/key to recipients (if changed)
    for each new customer:
    1.  verify customer, reveal account/passwd/file/key
  Customer:
    initial prep:
    1.  obtain and install pgp
    for each release:
    1.  convince distributor to give access information (if changed)
    2.  ftp encrypted file
    3.  decrypt
Public Key System:
  Distributor:
    1.  setup anon ftp account & directory
    4.  encrypt with current list of recipients
    5.  copy into anon ftp directory
    6.  notifiy recipients
    1.  get & verify customer's public key
    2.  add to keyring
    3.  add customer's key id to encryption script
    4.  re-encrypt tarfile (keep copy of unencrypted tarfile or decrypt/encrypt)
    5.  notify customer
  Customer:
    2.  generate a public key - private key pair
    3.  convey public key to distributor
    4.  convince distributor that it is the correct customer's key
    5.  wait for re-encryption
    for each release:
    1.  access anon ftp and obtain encrypted file
    2.  decrypt
Summary:
Effort of public-key encryption is greater at startup for both distributor
and customer but new-key distribution is eliminated.  The hard part in either
case is key management - in one case giving the correct parties the key, in
the other accepting public keys from the correct parties.  The difficulty of
doing these are essentially equivalent.  Even though public keys can be
emailed or posted without loss of security the verification process still
requires the same kind of secure channel and confidence that passing the
private keys requires.
I like Tony's public-key solution but it appears to be somewhat more work.
The private key system minimizes the distributor's effort for each new
customer.
The final choice should be by the distributor.
Alan K Biocca
Prev: Re: Making releases Jeff Hill
Next: Re: Making releases Bob Dalesio
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
