1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS 3.12 questions
Date: Wed, 15 Feb 1995 14:38:50 -0800
I'm trying to upgrade my EPICS 3.11.1 applications to run under 3.12.0.  In
building the database, I made a short report under 3.11 dct and created a new
database using v1.15 dct under 3.12.  Then I modified from text file with the
short report I made.  Then I sf2db to generate a .db file which is loaded by
dbLoadRecords after default.dctsdr is loaded by dbLoad.  The dbLoadRecords
results in:
Cannot set field TEVL to a
Cannot set field ELVL to b
Cannot set field TVVL to c
Cannot set field TTVL to d
Cannot set field FTVL to e
Cannot set field FFVL to f
It turns out that these are my mbbi records and it appears that hex values are
no longer allowed for these fields, even though dct now shows a 0x in front of
each value and allows you to enter these values.  However, dct won't let me put
in leading zeros to try and solve this problem.  If somebody's got a fix, could
we please have it?
Secondly, perhaps I've missed it somewhere (in which case please point me in
the right direction), but I haven't seen a translation tool to convert OPIs,
either .dl or .adl files from 1.16 edd/dm to 2.0 edd/dm.  What do I need to do
to bring up my old displays?  I really hope I don't have to redraw them.
Any help is greatly appreciated!
		Ric
Prev: Re: Releases and Security watson
Next: Re: EPICS 3.12 questions Rozelle Wright
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
