1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS 3.12 questions
Date: Thu, 16 Feb 1995 08:47:19 -0600
I just tried this on my system and it works fine.
My guess is that you are still getting the old version of dct when you think
you have the 3.12 version. I just noticed that the dct version number was never
updated so looking at the dct version does not help.
Please type "which dct" and see if you are using the 3.12 version.
Here is what is supposed to happen:
All new dct tools (sf2db, atdb, etc) use the static database access library.
It, in turn, always write CT_HEX fields with a leading 0x. When it converts
from ascii to int it uses strtol (ASCII standard library routine) to perform
conversion. This allows a leading 0x for hex and leading 0 for octal.
Previously DCT wrote CT_HEX field in hex without a leading 0x. It was modified
so that it accepts fields CT_HEX fields with or without a leading 0x.
This if you do the following:
1) use new DCT to restore from short form report
2) generate new short form report
3) use sf2db on new short form report
then it should work just fine. The .db file should have a 0x in frount
of all CT_HEX field values.
Since this is what you said you did, my olny guess is that you are still
getting the old version of DCT.
Marty Kraimer
> From [email protected] Wed Feb 15 16:39 CST 1995
> Date: Wed, 15 Feb 1995 14:38:50 -0800
> From: Ric Claus <[email protected]>
> Subject: EPICS 3.12 questions
> To: [email protected]
> Reply-To: [email protected]
> X-Envelope-To: [email protected]
> Content-Transfer-Encoding: 7BIT
> Content-Type> : > text>
> Content-Length: 1739
> I'm trying to upgrade my EPICS 3.11.1 applications to run under 3.12.0.  In
> building the database, I made a short report under 3.11 dct and created a new
> database using v1.15 dct under 3.12.  Then I modified from text file with the
> short report I made.  Then I sf2db to generate a .db file which is loaded by
> dbLoadRecords after default.dctsdr is loaded by dbLoad.  The dbLoadRecords
> results in:
> Cannot set field TEVL to a
> Cannot set field ELVL to b
> Cannot set field TVVL to c
> Cannot set field TTVL to d
> Cannot set field FTVL to e
> Cannot set field FFVL to f
> It turns out that these are my mbbi records and it appears that hex values are
> no longer allowed for these fields, even though dct now shows a 0x in front of
> each value and allows you to enter these values.  However, dct won't let me put
> in leading zeros to try and solve this problem.  If somebody's got a fix, could
> we please have it?
> Secondly, perhaps I've missed it somewhere (in which case please point me in
> the right direction), but I haven't seen a translation tool to convert OPIs,
> either .dl or .adl files from 1.16 edd/dm to 2.0 edd/dm.  What do I need to do
> to bring up my old displays?  I really hope I don't have to redraw them.
> Any help is greatly appreciated!
> 	Thanks,
> 		Ric
Prev: Re: EPICS 3.12 questions Rozelle Wright
Next: Building Epics R3.12 Nick Rees
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
