1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Channel Access Under Linux
Date: Tue, 21 Feb 95 09:29:37 MST
> Also, I haven't worried about the endian issues yet.
> Scanning through the code, it seems like I just need to set the proper
> flags in base/src/ca/os_depen.h.  Is this right?
Most likely that will be all that is required. If you add additional
lines to the endian switch in os_depen.h please branch on the
architecture type and not the os type. Please send any changes
once you have tested.
Jeff
______________________________________________________________________
Jeffrey O. Hill			Internet	[email protected]
LANL MS H820			Voice		505 665 1831
Los Alamos, NM 87545 USA 	FAX		505 665 5107
Prev: Re: (NI GPIB on linux) Gerry Swislow
Next: sf2db Ric Claus
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Channel Access Under Linux John Quintana
Next: Re: Mark S. Engbretson (BESSRC-Cat)
