Subject: |
versioning ioc startup scripts for a control system |
Johnny Tang <[email protected]> |
Date: |
Sat, 11 Mar 95 19:08:51 EST |
Johnny Tang Voice: (804)249-7239 E-Mail: [email protected]
Continous Electron Beam Accelerator Facility
12000 Jefferson Avernue, MS 85A
Newport News, Va 23606
Mailer: Elm [revision: 70.85]
I would like to open a discussion on versioning ioc startup
scripts for a control system. I will use CEBAF as an example
and summarize some of our thoughts on the issure. Any comments,
suggestions or ideas are welcome and appreciated.
Problems:
1. Managing ioc startup scripts for a single ioc system is
trivial. However, it become a little more complicated when
there are multiple iocs and a different set of applications
(like bpm, magnet, viewer etc.) may be loaded on each different
iocs. Things even get worse when there are multiple versions of EPICS
systems and multiple versions of applications running among the iocs
in a control system.
2. Ideally the EPICS system/application developers should test
their new developed codes on the fully simulated test iocs
and then install the codes on operational iocs. However in some
cases the fully simulation is away to expensive, so an operational
test-run for the new code is required. In case of the testing failure,
the previous operational version is required to be restored quickly.
It is not always true you can determine a testing failure /success
within several minutes or hours.
Solution to the problem:
The problem described in 1 can be presented in a matrix form as
following:
Version_Tag[ ioc_inx, app_inx ]
ex.
ioc1 ioc2 ioc3 ioc4 .....
epics 3.11a 3.11b beta8 beta8 .....
bpm 4ch1.0 NULL NULL NULL .....
rf NULL rf2.1 rf3.3 rf3.3 .....
fsd fsd1.0 fsd1.0 fsd1.1 fsd1.1 .....
Each version of the matrix is a version of oprational ioc
startup scripts.
1. All applications are required to check into cvs with a tag
before install it onto operational iocs. One suggest is to
check out the application from CVS and build its operational
copy of database files and modules.
2. An GUI interface to represent the Version_Tag matrix and
a set of version selection choices are helpful to quickly
update the ioc startup scripts automaticlly.
Johnny Tang
Accelerator Software Control --- System Group
CEBAF
Re: Reserved operand fault using CA on VMS Jeff Hill
Work needing support Bob Dalesio
<1995>
2025
2026
<1995>
2025
2026
