1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Understanding the time support on Epics.
Date: Fri, 24 Mar 1995 10:26:52 +0000 (GMT)
Regarding leap seconds in EPICS timestamps :
The number that is held in the EPICS timestamp (seconds/nanoseconds
since epoch Jan 1 1990) does *not* actually represent the precise
elapsed time since the epoch : leap seconds are ignored and so the
number of seconds in the timestamp is slightly less than the actual
elapsed time.
It only matters if an elapsed time is calculated from a pair of EPICS
timestamps and a leap second ocurred during the period between the
two timestamps. There is also a problem during the leap second
itself - an ambiguity in the timestamp value which is the same for 2
successive seconds.
There is nothing unusual about this : this behaviour is identical to
using a standard Unix (POSIX/ANSI C) time value = "Seconds since Jan 1
1970". Again, this does not actually represent the precise number of
seconds that have elapsed since the epoch since leaps are ignored but is
simply a way of representing time as a single integer, the standard
routines convert to/from UTC using a simple formula ignoring leaps.
Apparently there are proposals under way to include leap second handling
in a defined way in future C and Unix standards but at the moment the
problem is ignored.
Philip
Philip Taylor, Royal Greenwich Observatory, Madingley Road, CAMBRIDGE, UK.  CB3 0EZ.
Email : [email protected]                              Phone : (UK+) (0)1223-374710
Prev: Re: Understanding the time support on Epics. John R. Winans
Next: EPICS Arcnet Drivers. David Barker
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
