1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Changing SCAN field dynamically
Date: Tue, 18 Apr 1995 10:38:01 -0500
> >    a) set the HSCN to special type SPC_MOD.
> >    b) In the special routine call dbPut to change the SCAN field.
> >        Note that changing it yourself will not have the desired effect
> >        because it is not removed or placed in the appropriate scan list.
> >     Again this seems unnecessary. Just let the user change the SCAN field.
>   The requirement is NOT for the user to change the SCAN field but the magRec
>   to change its SCAN field because this needs to happen automatically and
>   it knows when to do it.
In this case I suggest the following:
When and only when it is time to change the scan choice call dbPut to
Marty Kraimer
Prev: Re: Device driver for NOAO instrument John R. Winans
Next: caWave and -lansi mcgehee
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Changing SCAN field dynamically Marty Kraimer
Next: Device driver for NOAO instrument Richard Wolff
