1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS extensions porting to Solaris (native) and IRIX
Date: Tue, 16 May 1995 09:21:56 -0500
> >libLseq5.a              needs gcc      needs gcc       needs gcc
> I made it using acc3.0.1/SunOS4.1.3, with no problem.
> Why don't you use acc?
I remember that libLseq5.a have to use gcc on Sun4.  The acc created
libLseq5.a  can not spawn the multi task correctly.
Did you try to run a simple test program, see whether acc generated
libLseq5.a can spawn the multi task seq program correctly on Unix?
Ben-chin
Prev: Re: EPICS extensions porting to Solaris (native) and IRIX Muranaka Masaki
Next: Re: Anyone using fast ethernet in their IOCs? Malcolm Stewart
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Anyone using fast ethernet in their IOCs? mcgehee
