> If you look at Beta13 you'll see that I already fixed this, and in fact Nick
> Rees added to my changes as well since. It now uses a case on the configured
> HOST_ARCH to split up the different architectures, and with Nick's changes it
> can also take the HOST_ARCH as a parameter. I'm not sure if Janet has applied
> Nick's changes to the repository yet, but the Beta13 version works in normal
> circumstances (it fails if you are using multiple host architectures and you run
> it on a different architecture to the HOST_ARCH setting in CONFIG_SITE).
Note that my changes to blderrSymTbl are not required if the HostArch
shell script is used to determine HOST_ARCH - Andrews original
version works OK, and is cleaner. Alternatively it can use the HostArch
script directly instead of using `GetVar HOST_ARCH`.
Nick Rees
Joint Astronomy Centre Ph: +1 (808) 961-3756
660 N. Aohoku Place Fax: +1 (808) 961-6516
Hilo, HI. 96720 Internet: [email protected]
Re: TTL --> fibre Bill McDowell
e2sr name mangling William Lupton
<1995>
2025
2026
Re: Solaris 5.x changes to blderrSymTbl Andrew Johnson
<1995>
2025
2026
