1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: e2sr name mangling
To: [email protected] (Matthew Needes)
Cc: [email protected]
Date: Mon, 19 Jun 95 14:39:46 -0400
RE: Matt Needes proposed changes to e2sr:
I believe the whole approach of extensive use of properties and substitution
in the schematic itself is clumsy, in that it requires additional work to
maintain the schematic.  At CEBAF, we have used an additional utility program
which encapsulates our desired naming convensions into rules, which operate
correctly (99.9% of the time) on any record anywhere in the hierarchy, so that
there is no burden to editing the schematic to get the names right.
I think it would be a good idea to merge the two capabilities of e2sr and
our name mangling program, but it should not be dependent upon setting
properties in each record, but should instead be completely rule based.
Chip
Re: e2sr name mangling Matthew Needes
Prev: Database Changes - New ascii file formats Marty Kraimer
Next: Proposed epics/base changes Janet B. Anderson
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: e2sr name mangling Matthew Needes
Next: Re: e2sr name mangling Matthew Needes (LANL)
