1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS_CA_ADDR_LIST in R3.12Beta13CEBAF
To: [email protected], [email protected]
Cc: [email protected]
Date: Mon, 17 Jul 95 09:43:18 MDT
>  Does anyone use EPICS_CA_ADDR_LIST environment variable in R3.12Beta13?
> I installed R3.12.0Beta13CEBAF on our HP-WS. ca_test cannot find a channel
> on IOC. The older version of ca_test , which also uses EPICS_CA_ADDR_LIST
> variable , can find the channel. In our configuration, IOC's and OPI's
> belong differenct sub-nets and channel search by bradcast will not work.
A known problem with R3.12.0Beta13 occurs when all of the following
are true.
o The server receives a channel name resolution (search) UDP request
	from off subnet
o There isnt a route in vxWorks to the sender of this request
In this situation the UDP task discovers the error and suspends itself
rather than continuing to service requests as it should.
Symptoms:
o No route to destination message on the IOC's console and in the log file.
o Suspended CA UDP task in the IOC.
o IOC's CA server stops receiving new connections.
Work Around
o Add a default route to your IOC:
	hostAdd "myrouter", "N.N.N.N"
	routeAdd "0", "myrouter"
	Type "netstat -r" on a UNIX host to determine the
		address of a router.
We have known about this problem for awhile but have been discouraged from
checking a patch into CVS until an official release of R3.12.1 occurred.
I suggest that APS create a CVS branch so that fixes of this nature can
be applied to R3.12.2 (while future EPICS development continues on the
main CVS branch).
Otherwise there are no known problems with the use of EPICS_CA_ADDR_LIST.
Jeff
______________________________________________________________________
Jeffrey O. Hill			Internet	[email protected]
LANL MS H820			Voice		505 665 1831
Los Alamos, NM 87545 USA 	FAX		505 665 5107
Prev: CA-ADDR-LIST Johnny Tang
Next: [no subject] Andy Foster
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS_CA_ADDR_LIST in R3.12Beta13CEBAF Johnny Tang
Next: Re:EPICS_CA_ADDR_LIST in R3.12Beta13CEBAF Noboru Yamamoto
