1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Internal type conversion in Epics
To: Epics Questions <[email protected]>
Date: Tue, 18 Jul 1995 16:26:14 +0100 (BST)
I'm working on the International 8m Gemini Telescopes project
which is using EPICS for software control. I recently came
across the following problem and was wondering if anyone else
has experienced the same thing:
I have tried to pass down a double into a record which only
accepts strings. This record has been written especially for
the Gemini project and is known as a CAD record. Since
the CAD only accepts input strings, I had to do this by first
converting the double into a string using something like:
sprintf( pcad->inpa, "%0.15f", val );
Inside the routine that the CAD record calls, I had to do:
val = strtod( pcad->inpa, &c );
This worked fine but seems to be a bit of an overhead for
passing in a double!
I had previously thought that EPICS would do this sort of conversion
automatically. However, when I tried this I found that I lost a great
deal of accuracy in the value that I was passing in.
For example, I tried to pass 9.564328761234322 through
the output link of a double into the CAD input field. The result after:
was 9.564330000000000.
Is this what you would expect or am I missing something obvious
and important?
Andy Foster
Royal Greenwich Observatory		Tel:    44 (0)1223 374899 (direct)
Madingley Road				E-mail: [email protected]
Cambridge
CB3 0HA
UK
Prev: [no subject] Andy Foster
Next: [no subject] Andy Foster
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Internal type conversion in Epics Marty Kraimer
