R3.12 BUG Report (CA fails under HPUX)
SYMPTOM:
CA client never connects under HPUX. Problem has not been reported
on other OS.
FIX:
Install the attached replacement for cac_time_diff() into
base/src/ca/access.c
A patch to R3.12 is pending creation of a CVS branch at APS.
EXPLANATION:
This problem stems from a fundamental difference between
the timeval data structure under under HPUX and under other
OS such as SUNOS4:
HP UX:
struct timeval {
unsigned long tv_sec; /* seconds */
long tv_usec; /* and microseconds */
SUNOS4:
struct timeval {
CA isnt expecting tv_sec to be unsigned. When it is unsigned
this causes a drastic change in the arithmetic in cac_time_diff().
Of course all of this results from there being no way to fetch
sub sec granularity time in POSIX. The result is we end up calling
the defacto standard BSD gettimeofday() which uses struct timeval.
Jeff
* cac_time_diff()
ca_real cac_time_diff (ca_time *pTVA, ca_time *pTVB)
ca_real delay;
ca_real udelay;
* works with unsigned tv_sec in struct timeval
* under HPUX
if (pTVA->tv_sec>pTVB->tv_sec) {
delay = pTVA->tv_sec - pTVB->tv_sec;
else {
delay = pTVB->tv_sec - pTVA->tv_sec;
delay = -delay;
if(pTVA->tv_usec>pTVB->tv_usec){
udelay = pTVA->tv_usec - pTVB->tv_usec;
else{
delay -= 1.0;
udelay = (USEC_PER_SEC - pTVB->tv_usec) + pTVA->tv_usec;
delay += udelay / USEC_PER_SEC;
return delay;
______________________________________________________________________
Jeffrey O. Hill Internet [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos, NM 87545 USA FAX 505 665 5107
SNL reconnects across CA Andy Foster
Re: error in compiling xmca Ben-chin K. Cha
<1995>
2025
2026
default.dctsdr Marty Kraimer
<1995>
2025
2026
