>One of the VME crates should provide up to 15 serial interfaces (RS-232)
>and 10-12 analog inputs. However, we were wondering which VME boards or
>modules are supported by EPICS. The List of Supported Hardware distributed
>through the ANL WWW server seems to be somewhat out of date (1993).
You might do this job with a single 162 if you choose:
2 IP-OCTAL (Green-Spring)
1 32 channel A/D from Acromag or any other ...
In case you might need additionel signals like DIN's and DOT's an D to A
you might be better off with the IRM from Fermilab which covers all the
direct I/O and you still can add two IP-OCTAL's to handle the serial lines.
Drivers for the IP-OCTAL come with the IP-module, EPICS support for these
can be obtained from us. IRM driver are also available from us.
Regards
Matthias
Matthias Clausen Deutsches Elektronen Synchrotron
Gruppe: MKV2/KRYK DESY/Hamburg, Germany
Re: error in compiling xmca Ben-chin K. Cha
Re: Bug in command line shell caget Ben-chin K. Cha
<1995>
2025
2026
Re: Hardware Supported by EPICS winans
Re: Hardware Supported by EPICS Steve Lewis
<1995>
2025
2026
