1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ca question
To: [email protected]
Date: Fri, 4 Aug 95 17:15:58 MDT
R3.12 BUG Report
(CA client fails to properly clear event when channel is disconnected)
SYMPTOM:
Assert failure in bucketLib.c when ALH/probe exit and the IOC is
disconnected.
FIX:
Properly clear event resource when IOC is disconnected.
A patch will end up in a 3.12 bug fix release.
EXPLANATION:
This bug occurs when all of the following are true:
o You called ca_clear_event() prior to calling ca_clear_channel() instead
	of calling only ca_clear_channel() (and letting it clear the event).
o The channel was disconnected when you cleared the event.
It appears that this leak has existed for a very long time and was not
detected because most applications call ca_clear_channel() to clear
both the event and the channel. This was caught because the new resource
id table code didnt allow itself to be deleted while a resource id was still
in use.
Jeff
______________________________________________________________________
Jeffrey O. Hill			Internet	[email protected]
LANL MS H820			Voice		505 665 1831
Los Alamos, NM 87545 USA 	FAX		505 665 5107
Prev: Re: CA server message buffers Peregrine McGehee
Next: [no subject] Matt Bickley
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: UAE - the Universal Application Environment Nick Rees
