1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Display Manager Problem
To: [email protected]
Date: Mon, 21 Aug 1995 11:31:08 +0100 (BST)
All,
We have noticed an inconsistancy with values displayed by the display manager (dm).
We have an application which requires a number of dm displays to be shown on a single
terminal, a number of the displays may show the same data.
It has been noticed that although the links for the different displays are to exactly
the same records, the displays often show different values.
On closer inspection it appears that the errors occur when a display is started,
at this time the new monitor does not return the same value as a display already active,
even though the active display is showing the correct value, consequently, unless the value
monitored changes then the two displays will be reporting different values forever more.
If a monitored value does change then it appears that all displays are updated correctly.
Has anybody noticed this same problem, or is it specific to our application/setup ?
Or, has anyone a solution to this, or suggestions as to where to start ?
Thanks
Paul Martin
Royal Observatories
Madingley Road,
Cambridge,
CB3 0EZ
England.
EMAIL: [email protected]
Phone: (UK) 01223 374841
Prev: Re: UAE - the Universal Application Environment Nick Rees
Next: Display Manager Problem Paul Martin
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: VME IO scanner 6008-SV Marty Kraimer
