1994  <1995>  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <1995>  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: output record initialization
To: [email protected]
Date: Tue, 5 Sep 95 20:29:50 +0200
re: adding fields IVAL and FINI
I'm reluctant to add new fields for every new feature desired. (In fact,
I would like to remove a lot of fields!)  For the few times where this
is necessary, can't it can be accomplished by using the SIM fields and
PINI to first fetch a "simulation" value, then have that flip it out of
simulation mode so that the next execution fetches the DOL value?
It can also be solved by using a couple of soft records pushing into the
real record -- one for the initial value, the other for the later values.
Another possibility is to re-use PINI to be an enum to control initial
behavior, and allow the database designer to pre-load VAL (instead of
requiring IVAL).  Then the record does not have to get larger.  PINI
is 8 bits, and could hold both necessary flags.
Chip
Prev: Re: Q: NI-1014 GPIB board with Force CPU40. Noboru Yamamoto
Next: OMS VME 44 Stepper Motor Controller Sally Schaffner
Index: 1994  <1995>  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: output record initialization Gordon Uchenick
