1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Engineering Units
To: [email protected]
Date: Thu, 21 Sep 1995 10:41:53 -0500
Tim Mooney has pointed out a problem with get_units.
The problem is as follows:
Many record types define EGU to have 16 characters.
The record support modules get_units routine executes the statement:
   strncpy(units,prec->egu,sizeof(prec->egu));
Thus the record support module copies up to 16 characters.
However old and new database access only have 8 characters for units.
It turns out that getting units values via channel access NEVER overwrite
anything that is not updated AFTER the strings are copied. Thus the only
result is that channel access clients only get a max of 8 characters.
If 8 characters are obtained it probably is NOT null terminated.
I a database link asks for units info in a buffer that does not have
sufficient extra space after the DBRunits info bad things could happen.
No standard epics record/dev support asks for units info via database
options thus no problem can occur.
We can NOT change the sizes in old or new database access without recompiling
ALL Ca clients AND all ioc software. Thus we cant really do this until we
go to a new major release number of EPICS.
What we can do for now is to define a symbol MAX_UNITS_SIZE in dbDefs.h
and change all record support modules and ascii files to use this symbol.
Then when we go to next major EPICS release number we can just change
MAX_UNITS_SIZE and have everything automatically support units strings
of 16 characters.
Comments?
Marty Kraimer
Prev: Re: atomic updates of multiple fields possible? Tim Mooney
Next: Next Collaboration Meeting (etc...) Oct. 30th to Nov. 8th Bob Dalesio
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Engineering Units Tim Mooney
